- Thank you received: 1
Kevlar Clutch Discs? Anyone?
- 550A2
- keep the shiny side up
Anyone ever run these kevlar discs? if whats your opinion on em?
I could get the standard cork and aluminum ones too, but im curious about these.
It would be cool to know some first hand info about performance....
thanks,
luke
82 Honda ATC 200-sold
82 Yamaha Virago 920-sold
82 Yamaha YZ250j-kept
80 Suzuki GS 550-sold
82 Kawasaki KZ550 A2-ride all the time
79 Kawasaki KZ650 C-sold
73 Kawasaki Z1 900E-paid $200, sold $6000
86 Yamaha Radian YX600-new project
- APE Jay
- Banned
- Thank you received: 58
- Old Man Rock
- Thank you received: 225
Great kits for drag racing or in street racing setups where the need the extra plate biting, stronger springs high engine torques etc... but for street use, stick with the OEM/reproductions...
They they followed up with "They worked for 30 years in the old girl what makes you think they won't work now...."
Then there's this... Pending your age, left arm/hand fatigue.... These old beasts aren't hydraulic clutch, well at least my KZ900 isn't, and with heavier springs this will be harder to pull...
Just what I've learned anyways....
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- otakar
OMR
"What He said" :ohmy:
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- kzr750r1
- Thank you received: 9
Have still slipped it on occasion so well see what options are out there next round.
KZ750R1 + 1991 ZR750 = KZR750R1
Better to be shot out of a cannon then squeezed through a tube. - HST
- 550A2
But ehhhh, my hands arent too old, i can handle a little stiffer spring if it means a little better bite.
I'll probably end up sticking with a good quality standard kit, and maybe some stiffer springs.
any recomendations?
- Old Man Rock
Start lifting weights and squeeze a tennis ball with your left hand to build up endurance....
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- 550A2
Im talking about a brand of clutch kit someone might have had good results with......not my hand.
I turn wrenches all day, i dont need to squeeze a ball.
- Thank you received: 2829
Along with OMR's "Start lifting weights and squeeze a tennis ball with your left hand to build up endurance...." I'd say you need to start carrying a spare clutch cable along with the tools needed to install it at roadside.
No offense intended, but we're talking about a KZ550. Even with very spirited riding my original '77 KZ650 clutch went 36,000 miles before it needed to be replaced. I would think a KZ550 stock clutch would last at least that long if it is kept properly adjusted. It's your bike & money, but I wouldn't get too carried away with visions of higher performance from heavier clutch springs. My $0.02 Ed
- flht1997
Matt Milwaukee, WI
75' KZ400, (5) 78' KZ400, 76' KZ 750, 78' KZ650
78'CB750F, 78' CB550K
89' BMW R100RT
05' H-D Electra Glide
06' KLR650
Do it right or don't bother doing it at all.
- 550A2
Alright, first of all thank you guys....
I know the clutch is slipping because the adjusters are in as far in as they can go without exessive slack in the cable.
unless there is another adjustment?
No offense taken, i just want my bike to ride good man. And it would kinda blow having to lift weights to have the strength to work the clutch.
Ill get er going
