Kz650 Points Question?
- Cychotic
- No sir, I don't like it.
29 Jul 2009 02:19 #309999
by Cychotic
1977 KZ650 C1 with '78 C2 motor,
* OEM electronic ignition off '80 KZ750
* 4-into-1 header
* Uni Pod Filters
* #110 main jets, 17.5 pilot jets
1983 Honda V65 Magna stock...sold
1985 Kawasaki Ninja 600R project..sold
1997 Yamaha FZR600...latest toy
Replied by Cychotic on topic Kz650 Points Question?
Just curious to know what you did to fix it?
* 4-into-1 header
* Uni Pod Filters
- Thank you received: 2098
29 Jul 2009 03:34 #310000
by Patton
Replied by Patton on topic Kz650 Points Question?
Another tip regarding Dyna coil fitment is to assure no short (touching) between screw head attaching terminal wire and coil mounting spacer.
This is a close fit with very little clearance.
Could use a piece of rubber or other insulation beteen the screw head and spacer; or wrap the spacer with a nylon tie wrap; or use a nylon or other non-conductive spacer.
Nylon tie wraps work for me.
Good Luck!
[Click on image for larger view]
Good Luck!
- Kawickrice
- Thank you received: 18
29 Jul 2009 07:20 #310046
by Kawickrice
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
Replied by Kawickrice on topic Kz650 Points Question?
Cychotic wrote:
Yea what he said
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- oxcadillacxo
29 Jul 2009 08:27 #310059
by oxcadillacxo
78 Kz650 Sr
Replied by oxcadillacxo on topic Kz650 Points Question?
for the moment i jus put in a different points plate in gapped the points and set the timing.. once i get everything else i need i am going to buy a new Electronic ignition thanks for all the help
78 Kz650 Sr
- PLUMMEN
- Thank you received: 104
29 Jul 2009 08:31 #310061
by PLUMMEN
Replied by PLUMMEN on topic Kz650 Points Question?
bountyhunter wrote:
i didnt think he had points in there currently,wants to switch to pointsKawickrice wrote:
If you have fire on 2 cylinders something is opening your points. With no point cam no fire at all.
Good point, there has to be a cam of some kind in there. The "dead" side could have a bad condenser or the point wire grounded.
