Kz650 Points Question?
  • oxcadillacxo
  • Topic Author
27 Jul 2009 08:37 #309572 by oxcadillacxo
Kz650 Points Question? was created by oxcadillacxo
OK i bought 1978 kz650 for 100 dollars i got it to run but only on 2 cylinders (1-4) will run 2-3 no fire! so i thought it might be the coils but i hooked the trigger wires from coils 1-4 and put them on 2-3 and 2-3 fire then 1-4 dont so i guess its a ignition problem the bike has electronic ignition! i am going back to points system!
MY QUESTION IS WHAT SPINS AROUND TO HIT THE POINTS AND MAKE THEM WORK?? I BOUGHT A POINTS PLATE AND POINTS OFF EBAY BUT I DONT THINK I HAVE THE ECCENTRIC OR WHAT EVER ITS CALLED TO MAKE THE POINTS WORK ALL I HAVE IS THE ELECTRONIC IGNITION ASSEMBLY!
78 Kz650 Sr
27 Jul 2009 09:04 #309575 by mzandmz
Replied by mzandmz on topic Kz650 Points Question?
You need the unit that bolts on the end of the crankshaft, It should have the centrifuge advance device connected to as well
New to Family, 1979 KZ440 LTD
  • oxcadillacxo
  • Topic Author
27 Jul 2009 09:10 #309578 by oxcadillacxo
Replied by oxcadillacxo on topic Kz650 Points Question?
thats the advance right? i have that but my friend said that i would need something to make the points open and close
78 Kz650 Sr
27 Jul 2009 09:16 #309582 by KawiConvert
Replied by KawiConvert on topic Kz650 Points Question?
There is a cam that strikes the points to make them contact. It fits on the end of the crankshaft. Also, you no longer will need the ignitor box. Instead a 12v wire goes to both coils, and then a green or a black wire (one to each coil) to discharge the coil for spark. Pretty straight forward in some respects.
It appears someone has beaten me to it. Oh well.
1978 KZ650 D1 ~ Carb jetting: 107.5 & 20 & 4th groove with pods and 4-1 Exhaust
27 Jul 2009 09:17 #309583 by loudhvx
Replied by loudhvx on topic Kz650 Points Question?
The point's cam is part of the advancer, #15 on the drawing. It comes off easily and can be replaced, but I don't think you'll find it as a seperate part. It'll usually be part of the assembly.
However, Anyone that has converted to a Dyna S from points should have just the cam lobe for you. When they convert to the Dyna S they have to remove it and replace it with a magnetic rotor that comes with the Dyna S.
I would post a thread in the electrical forum and ask Dyna S users (on KZ 650's) if they want to sell the points cam.
  • oxcadillacxo
  • Topic Author
27 Jul 2009 09:21 #309584 by oxcadillacxo
this cam you speak of would it still be with the electronic ignition also or do you do away with it when you switch ? sorry if its a newbie question not much motorcycle exp.. mainly old cars here !
78 Kz650 Sr
  • oxcadillacxo
  • Topic Author
27 Jul 2009 09:23 #309585 by oxcadillacxo
my advancer looks just like the picture but it is smooth my friend said it had to have bumps on it to open and close points
78 Kz650 Sr
27 Jul 2009 09:23 - 27 Jul 2009 09:25 #309586 by loudhvx
Most of the electronic ignition kits will not use the point's cam, so whoever converted your bike, tossed it or still has it.
The ones for electronic ignitions will be smooth with a magnet imbedded, or will have a point to be sensed by a pickup, or will have a big plastic round thing for a light sensor.
I bet you could get a points cam from a member here with a 650 who did the conversion.
Last edit: 27 Jul 2009 09:25 by loudhvx.
  • oxcadillacxo
  • Topic Author
27 Jul 2009 09:26 #309587 by oxcadillacxo
its a really old electronic ignition the advance jus goes through the middle and at end of the advance cam is two prongs/slots for a nut to fit into
78 Kz650 Sr
27 Jul 2009 09:30 - 27 Jul 2009 09:31 #309589 by loudhvx
No eBay APP ID and/or Cert ID defined in Kunena configurationHere is one for sale:
Brand new, rare, and cheap (at the moment).
That is what it looks like (the bolt and end nut are missing). Notice how the outer part of the shaft is not centered with the hole. It's because it is a cam. The thick part goes around, it pushes on the points to open them.
Last edit: 27 Jul 2009 09:31 by loudhvx.
27 Jul 2009 09:33 - 27 Jul 2009 09:42 #309591 by loudhvx
It sounds like the whole rotor is missing. Someone must have taken the rotor and all you are seeing is the shaft of the advancer unit. (The rotor of an electronic ignition is what replaces the points cam.)
EDIT: this can't be right if you are getting spark on one of the coils.
Last edit: 27 Jul 2009 09:42 by loudhvx.
  • oxcadillacxo
  • Topic Author
27 Jul 2009 09:34 #309593 by oxcadillacxo
ok thats what i have i am think.. does the thick part come off? the part that the nut and bolt go through ! if not then i know thats what i have
78 Kz650 Sr
