Kz650 Points Question?
- oxcadillacxo
MY QUESTION IS WHAT SPINS AROUND TO HIT THE POINTS AND MAKE THEM WORK?? I BOUGHT A POINTS PLATE AND POINTS OFF EBAY BUT I DONT THINK I HAVE THE ECCENTRIC OR WHAT EVER ITS CALLED TO MAKE THE POINTS WORK ALL I HAVE IS THE ELECTRONIC IGNITION ASSEMBLY!
78 Kz650 Sr
- mzandmz
New to Family, 1979 KZ440 LTD
- oxcadillacxo
78 Kz650 Sr
- KawiConvert
- Thank you received: 4
It appears someone has beaten me to it. Oh well.
1978 KZ650 D1 ~ Carb jetting: 107.5 & 20 & 4th groove with pods and 4-1 Exhaust
- loudhvx
- Thank you received: 1616
However, Anyone that has converted to a Dyna S from points should have just the cam lobe for you. When they convert to the Dyna S they have to remove it and replace it with a magnetic rotor that comes with the Dyna S.
I would post a thread in the electrical forum and ask Dyna S users (on KZ 650's) if they want to sell the points cam.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- oxcadillacxo
78 Kz650 Sr
- oxcadillacxo
78 Kz650 Sr
- loudhvx
The ones for electronic ignitions will be smooth with a magnet imbedded, or will have a point to be sensed by a pickup, or will have a big plastic round thing for a light sensor.
I bet you could get a points cam from a member here with a 650 who did the conversion.
1981 KZ550 D1 gpz.
Other links.
- oxcadillacxo
78 Kz650 Sr
- loudhvx
Brand new, rare, and cheap (at the moment).
That is what it looks like (the bolt and end nut are missing). Notice how the outer part of the shaft is not centered with the hole. It's because it is a cam. The thick part goes around, it pushes on the points to open them.
1981 KZ550 D1 gpz.
Other links.
- loudhvx
its a really old electronic ignition the advance jus goes through the middle and at end of the advance cam is two prongs/slots for a nut to fit into
It sounds like the whole rotor is missing. Someone must have taken the rotor and all you are seeing is the shaft of the advancer unit. (The rotor of an electronic ignition is what replaces the points cam.)
EDIT: this can't be right if you are getting spark on one of the coils.
1981 KZ550 D1 gpz.
Other links.
- oxcadillacxo
78 Kz650 Sr
