- Thank you received: 1
kz 900 alternator rotor end crank shaft taper.
- arai59
- Banned
- benjamin
- benjamin
- gane
[img][/img] 1977 KZ1000A1
- 1978z1r
- Kraz1
hello, please tell me the difference between the two crank tapers. thanks, marc...
1978z1r wrote:
It is a frustrating conversion to switch stator/alternators between that year and the 80. The crank is different altogether on the MKII. It has a wider end and requires a larger bolt on the larger cranks. I have a 78Z1r that I tried to switch to a 76 Z1 dynamo. No key slot on the Z1R because of the heavier crank. Check the inside portion of the dynamo and make sure that it is not bored out beyond tolerance. My Z1R dynamo let loose and sheered out the inside and replacing it was quite a task. The only conversion that I have been made aware of from 80 to 76 requires a great deal of crank modification.
So now that you're more acquainted with the differences in the Crankshafts, etc, etc.. What was the course of action?
- benjamin
- Kraz1
