kz 900 alternator rotor end crank shaft taper.
- benjamin
- KruZer
My manual says;
"Apply loctite to the rotor mounting bolt before istallation, and tighten the bolt with 18 ft-lbs (2.5 kg-M) torque."
Also make sure the thick shim that goes against the crank has the "chamfer" side toward the crank.
Buzz
*1977 1000, 1975 KZ998 LSR bike.
- Thank you received: 2098
We're glad you're here!
Here's some info from another thread that might possibly be helpful.
Make sure the bolt is in good condition and has not stretched.
Make sure the threads on the both the bolt and the crank are clean - if you have any debris in the crank thread, you may be torquing against the debris rather than tightening the rotor.
...also, make sure the cast aluminum part of the rotor has not started to pull away from the hex steel center. If you have any sign of play / crack, replace the rotor.
Good Luck!
- Kraz1
- benjamin
i have a 1976 kz 900. the bolt that holds the rotor on the crank shaft came loose and sheered the woodruf key for the rotor. i also found damage to the starter clutch, small and large thrust bushings and the bearing from the crankshaft to starter clutch twisted and trashed. that bearing looks like a large version of a smal end rod bearing. i have a 1980 kz 1000 engine that i have pulled all of the parts off of to get the 900 going again. i was able to get the remains of the woodruf key out of the crank easily with a pick. there was no apparant damage to the crank or taper unusually. after cleaning up the pieces, lubeing them and begining installation i ran into a problem. i used the bolt from the 1000, both were the same, and as i was torqueing it it felt like there was no contact and the bolt finally broke. the manual i have says that the bolt should go to 116 foot pounds. after removing the broken remains of the bolt from the crank i found a stronger bolt of same thread and pitch and tryed a beam type torque wrench, i could only get to about 55 foot pounds before it started to feel like the bolt was starting to stretch. all of the bushings are in place, the rubber damper seems ok, the woodruf key is in the crank correctly. kind of at a loss right now with this. your thoughts and ideas would be greatly appreciated. i used the rotor and clutch assembly from the 1000, starter pinion gear from the 1000. the only thing from the 900 on that side of the engine is the crank and sidecover.
The FSM for Z1~KZ900 specifies Loctite and 18 ft-lbs . That's "eighteen" ft-lbs.
1977 KZ1000 is 16.5~19.5 ft-lbs (with Loctite).
1978 KZ1000 increased to 51~54 ft-lbs (No loctite).
1979 KZ1000 increased to 94 ft-lbs (No Loctite).
Good Luck!
- jtmcculloch
76 KZ1075
93 ZR1100
71 Moto-guzzi 750
2001 ZR-7S
- Kraz1
- benjamin
- PLUMMEN
- Thank you received: 104
- Kraz1
thanks to all who expressed their thoughts and ideas. i believe it was a simple stupid mistake. i was using the wrong manual for the job. as posted earlier, i looked up the correct torque value and it was 18 ft lbs. thanks you guys.
by the way, the latest post shows two different style rotors, one appears to be a "male" and one is a "female" style in terms of how it rotates inside or outside of the stator. thanks again, now i can move on to the nest step of the project.
thanks again and happy safe riding to all, marc.... HAPPY FATHERS DAY TOO!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Benjamin/Marc, Please review the "Crankshaft Tapers" "Woodruff Key" "Style Of Dynamos" note the differences in a 1976 Crank, and a 1980 Crank. I sent you a PM last night, and I'm not sure if you understand how the Member to Member Message System works. There are no stupid mistakes when you're learning.
Early Cutaway Showing "Key Way"
Early Dynamo (Alternator)
Later Dynamo (Alternator) Break-Down "No Woodruff Key".
Which Crank are you using? And what Parts are you using on Which Crank?
