KZ900 69.25mm two (2) ring pistons - anyone?
- KruZer
I found a set of KZ900 pistons that are 69.25mm and 10.5:1 compression (first set I've ever seen)!
The pistons only have two rings, a compession ring and a oil ring.
The rings I received with the pistons look like their in great condition but I would like to have a spare set.
Anyone ever hear of this piston setup? Any ideas where I might look for a set of rings?
Thanks,
Buzz
*1977 1000, 1975 KZ998 LSR bike.
- kaw74z1
- 0 to 60 in 15 minutes.
1974 Z1 with a MKII And a 1105 big bore kit 10.5 to 1 comp. Andrews 2x cams ported head dyna s with green coils V&H sidewinder pipe airshifter 4in.over arm
- KruZer
The only markings on the pistons are;
Z1 69.25
Buzz
- kzz1p
- One Test Is Worth A Thousand Expert Opinions!
- Thank you received: 3
I can't remember very well. I think Henry Abe (or whatever) had a single compression ring. I think years ago K&L supply sold some. I'm not sure, but did the YOSH 998cc kit have a single ring, setup?
Is it a 1 peice cast oil ring? or a three peice?
- kzz1p
Are they a flat dome, cast piston? Not like the newer style, that fits into the combustion chamber?
- KruZer
Buzz
- kzz1p
- kzz1p
- KruZer
Yes those are the pistons.......only your's are shinnier(sp) than mine...
- kzz1p
Gotta love you guys and this site!!!
Buzz
You didn't say witch of the two sets (round dome or pop up)
Is it a normal skirt or a slipper style skirt?
- kzz1p
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
