kz 650 with gpzcamsProblems! Its ALIVE THANKS
04 Jun 2009 16:13 #296346 by odl666
"rich, probably too rich. Check compression or cam timing to verify it has the vacuum to pull in enough fuel. If the intake cam is retarded it will be doggy and soggy"
WOuld this make the bike hard to start if the intake cam is a little retarded? Thanks!
1978 kz 650b with gpz faq mods cams carbs polished and ported
1979 gs750e
1972 bsa lightning under construction
04 Jun 2009 17:04 - 04 Jun 2009 17:06 #296351 by odl666
Replied by odl666 on topic kz 650 with gpz upgrades Problems!
Patton wrote:
Thinking the rotor is 180 degrees off and should be repositioned so that rotor magnet faces left-side module when 1-4 F mark aligns. The magnet causes the module to interrupt ground from the coil primary winding, which causes the coil to fire through its secondary loop including the two spark plugs.
And would double-check identity of which coil has plug wires going to outside plugs (cylinders #1/4), and that the signal wire from left-side Dyna-S module is attached to that specific coil.
Thinking first assure it's hooked up correctly, and then go from there.
Good Luck! :)
Thanks for the help after looking at the pics and thinking instead thinking it was like my gs 750 i figured out that i may of had the ignition set up wrong the whole time. do u think the bike would still start if i had the 1-4 2-3 wires switched but had the rotor 180 out? thanks for the help patton i just noticed on the dyna instructions that the white and black wire are different than the actual ignition the one on the instructions is green 2-3 and black 1-4 on my bike they are white 1-4
(because it did but ran crapy and would not idle) and black 2-3. I am gona try this out thanks again for opening up my mind. Cheers!
1979 gs750e
Last edit: 04 Jun 2009 17:06 by odl666.
