kz 650 with gpzcamsProblems! Its ALIVE THANKS
30 May 2009 15:53 - 02 Jun 2009 20:47 #295107 by odl666
JUST ONE MORE QuESTION?have currently completed my kz 650 with gpz cams with 25 thous milled off head with polished and proted rebuilt head with new bore 2 over pistons and new rings. I also have gpz carbs and ape filters. I have degreed the cams and it also has a supposedly rebuilt head. I am having trouble starting the bike it is kick start only and it has a strong spark. I also shimmed the valves to spec. Why isn't this lil bastard not staring any suggestions? thank you ahead of time!
1978 kz 650b with gpz faq mods cams carbs polished and ported
1979 gs750e
1972 bsa lightning under construction
Last edit: 02 Jun 2009 20:47 by odl666.
30 May 2009 16:37 #295123 by Mark Wing
Replied by Mark Wing on topic kz 650 with gpz upgrades Problems!
Not sure, how about the timing? Maybe try a little starting fluid.
Mark
Yorba Linda Cal.
30 May 2009 17:19 #295129 by odl666
Replied by odl666 on topic kz 650 with gpz upgrades Problems!
got a dyna s. So does that mean i need to time the ignition to make work i thought they kinda timed them self or at least enough to get it running without setting it.
1979 gs750e
30 May 2009 17:30 - 01 Jun 2009 09:40 #295131 by bill_wilcox100
Replied by bill_wilcox100 on topic kz 650 with gpz upgrades Problems!
odl666, I have the Dyna S and matching Dyna Coils and when I installed it I had to go through a two part timing procedure:
- Static timing
- Dynamic timing (Timing Light)
The Dyna S comes with all the timing procedure information.
Do you have it? If not, see here for the procedure I received with mine (DS2-2):
Link
Best of success. :)
Bill
PS
Add your year, model and location to improve the quality of responses... and it's considered real friendly too.
Bill
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
Last edit: 01 Jun 2009 09:40 by bill_wilcox100.
30 May 2009 18:55 #295144 by odl666
Yes i do have the directions to hook up the dyna s i have not static timed the bike but on the suzuki gs i had i just plugged in the dyna s and set it at twelve a clock and used a timing light later to dial it in. Ihave 1978 kz 650 b and i am located in albuquerque new mexico. Thanks for any other help that can be provided
1979 gs750e
01 Jun 2009 08:20 #295466 by Mellvis
Replied by Mellvis on topic kz 650 with gpz upgrades Problems!
If you have good compression, good fuel/air mixture getting into the cylinders, and spark at the right time, you should have a running engine. Check each of the basics. Are the plugs wet? Read the manual for timing instructionsand compare it to the Dyna instructions.
Good luck!
01 Jun 2009 09:07 #295472 by BSKZ650
Replied by BSKZ650 on topic kz 650 with gpz upgrades Problems!
you need to install the dyna according to the directions, also, I ran into a issue with mine the coil wires were backwards, no big deal, swap them and its all good.
also are the plugs wet from all the kicking, if so you may have gas fouled them, and NEW plugs will be needed
77 ltd1000, current rider
76 kz900, just waiting
01 Jun 2009 12:55 #295500 by odl666
i the problem is im not getting any gas to the plugs. im using 84gpz carbs 750. wat could be causing this i shimmefd the valves correctly. thanks
1979 gs750e
01 Jun 2009 13:20 #295503 by Patton
Replied by Patton on topic kz 650 with gpz upgrades Problems!
Begin by assuring enough gas in tank.
Assure ample fuel flow from:
Petcock;
In-line filter.
Assure ample fuel flow into:
Float bowls.
Assure float bowl fuel level is to specs (use clear tube test).
Assure float bowls are correctly venting.
Given ample fuel flow into float bowls at correct level with proper venting, blockage from the float bowl to the combustion chamber is usually in the carb pilot circuit.
Good Luck! :)
01 Jun 2009 17:31 #295569 by odl666
thanks i took apart the carbs I am also thinking maybe the carb boots are not getting a good enough seal any suggestions for adapting these gpz carbs to kz 650 head. I am also having problems getting the carb floats off becasue i cannot remove the pins any suggestions besides using something small to punch them out. thanks
1979 gs750e
01 Jun 2009 18:12 #295584 by bill_wilcox100
Caution! You punch you break! You need a new carb. Very fragile stuff :(
Bill
Upgrades:
Montreal, Canada
01 Jun 2009 18:17 #295586 by 650ed
Replied by 650ed on topic kz 650 with gpz upgrades Problems!
Put Kroil on the pins for a couple days and see if they free up. Ed
