2nd start post rebuild - obvious ticking noise vid
- sheik*yerbouti
I couldnt see any exhaust in your vid. :blush: I thought at first, like you that the sound your hearing was coming from the valve train, then I noticed one of my split collars wasnt seated.
Tom
There isn't much to see, just a header and slash cut beginning of a MAC pipe:
[img size=(499)] www.jasonfagan.com/siteAssets/graphics/kz1000_large.jpg [/img]
- RonKZ650
- Thank you received: 240
- HerrDeacon
- Thank you received: 1
- lapeerray
78kz650b2, 2009 kawasaki 25 hp Oturn John Deere with a 62" cut I had to have it. It was green and was powered by KAWI...,78 yamaha golfcar, Gone but not forgoten 82 v65 magna, 89 1200 Vmax, 72 GS380GT mint with 2000m.grandfather baught brand new in 72
- Old Man Rock
- Thank you received: 225
I would think with your hand in close proximity of the exhaust ports and with a twist of the throttle you should be able to feel the point of leakage... Yes/No?
Since you didn't mention any oil leaks of sorts, exhaust leak seems to be the culprit... Unfortunately with black painted cylinder/head and pipes, hard to say just where it is...
In using copper, one side is rounded and the other is flat sided. Rounded to the exhaust pipes, flat to the head.
Another neat little trick I learned from Plummen, Permatex copper gasket maker.... Just a light coat on the flat side to hold it in place in the head exhaust port. May find it seals the smallest of openings...
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- trianglelaguna
- Thank you received: 235
Tom
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
- sheik*yerbouti
no,no,no,no.....you don't just get to show a a picture of a bike that cool and get away scot free......we are gonna be needing a complete history and some more photos if you expect to get any more replies.......that has a story to tell i bet and we'll be needing some info........peace craig
Here is the basic writeup copy / pasted from my website...
Oh BTW it was an exhaust leak! Fixed and done, the valvetrain sounds like a sewing machine. Got to love it!
from www.jasonfagan.com --
1981 Kawasaki KZ1000 Vintage Superbike
Complete bare frame 600 hour custom build / Started December 2006 - First Ride July 14, 2007
Airtech Streamlining Fiberglass Replica Kawasaki H2R Race Tail sectioned and re-glassed to desired width
1969 Benelli Mohave 360cc 2.2 gallon fuel tank. 3/8" NPT custom machined fuel bungs TIG welded in
Tank was bead blasted inside and out then RedKote'd by a local radiator shop
Stock front fender lowered to follow smaller front wheel and chrome removed via bead blast prior to paint
Paint by local hot rod shop - PPG Moly Orange Mixing Tint shot as paint
Under side of tail / tank / fender sprayed with flat black rubberized underbody coating at paint shop
Checkered flag stripe kit by Steve Carpenter applied down spine of bike and is under clear coat
Over 30 individual parts power coated by Streetwerkz in Columbus, OH - Flat Black Textured
Frame gusseted per old Yoshimura frame gusset kit instructions - all tubing cut & fitted by hand
Seat rails cut out and new tubing welded in 4" higher to get seat on plane with tank
Over 1 foot of rear frame removed - upper shock mounts tied together - all unused mounts ground smooth
KZ1000 Police model swingarm - factory gussets, constructed with thicker tubing & thicker axle plates
Swingarm drilled and tapped for M8 aluminum spools for use with Pit Bull rearstand
Upper triple clamp cut flat on top removing perches all extraneous mounts removed
3/4" solid rod welded through frame and tapped to facilitate mount points for Honda CBR954RR rearsets
All brake calipers fully rebuilt, all pistons replaced with NOS OEM, K&L seal kits, Ferodo pads
Custom HEL Stainless Steel lines, rotors turned at local machine shop, 2001 Kawi ZX9R master cylinder
2003 Kawasaki ZRX1200 KYB Reservoir Style rear shock absorbers
Forks fully disassembled for power coat, stiffer .90 39mm Progressive fork springs, 30w non foaming oil
Real rubber 39mm fork gaiters from Kawasaki EJ (W650)
Adjustable NHK steering damper and billet aluminum PMFR 39mm fork clamp
Custom machined front axle spacers as stock mechanical speedo pickup removed
1981 Kawasaki 998cc 4-cylinder engine "J-motor"
Extensively modified by Bob Boyle and Gary Raff of Advantage Motor Works in Mansfield, Ohio
Wiseco 1075cc 10.5:1 Piston Set
Vance & Hines .435 Hot Street Camshaft
Cylinder Head from a 83 GPZ1100 with an electronic tach - mechanical tach drive hole not present
Cylinder head and bucket area clearanced to fit large cam and intakes smoothed out but not polished
Cylinder head and cylinder block both decked for absolute flatness
Cam cover smog passages welded shut, smog hardware removed, and machined flat on top
New APE Racing (Kibblewhite) Stainless Steel valves, APE HD Valve springs, APE Guides, APE oil seals
Barnett HD Clutch Springs - 2005 Suzuki GSX-R750 clutch perch and lever - Motion Pro clutch cable
Hand built manual cam chain tensioner by engine builder
Carbs done in Texas by "WiredGeorge" Motorcycle Carb Master George Lesho
Fully disassembled, cleaned, jetted and air passages enlarged / drilled / modified for the engine as built
Carbs soda blasted and rebuilt with all new rubber boots, new zinc plated fasteners, etc.
Dyna 3-ohm coils, Dyna-S pickup, Dyna 7mm copper wires, Dyna DRL300 Rev Limiter set at 10,000rpm
Modified Kerker 4-into-1 header, slash cut prior to muffler with 'sidepipe' style exhaust exit
Spring back automotive style ignition key start under right knee
Complete custom wiring harness from scratch with 16AWG 10-color wire, all soldered, ATC blade fuse box
One relay runs headlight / one relay runs coils / one relay runs gauge / turn signals / tail lights
Acewell instrumentation - speed / RPM / signal indicators / high beam indicator / neutral indicator / oil press.
Jeg's 0-15psi oil pressure gauge tapped and threaded into oil passage on motor right side
- Thank you received: 797
glad you had an easy fix.
leon holmes
- XL777
2012 Triumph Bonneville SE black
1978 KZ1000 B2 LTD
Fresh top end rebuild
Rebuilt head
Wiseco 1015 pistons
Dyna s
Green Dyna coils
Wired george mod
It is easier to say what I haven't replaced then what I have.
I must love this cruel mistress since she hates me
