2nd start post rebuild - obvious ticking noise vid
- sheik*yerbouti
At work will monitor thread no time to type now but will after lunch.
Discuss!
- Buda
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Vance&Hines pipe with comp baffle
dyna coils and wires
97 Valkyrie Standard
- sheik*yerbouti
- Buda
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
- Jack
- Thank you received: 7
79 KZ 1075 MKll
79 KZ 1500 MKll dragbike
Gone but not forgotten:
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
- Buda
Tom
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
- The Garbone
- User is Currently waiting for his bailout check..
2007 Royal Enfield Iron
1979 KZ650 & Hack
1949 Ford 8n
- sheik*yerbouti
Is there exhaust on that engine
yup a MAC 4-into-1 slash just behind the collector like a modern MotoGP look... loud!
- Buda
Tom
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
- sheik*yerbouti
Sounds like an exhaust leak to me. Much easier to remedy than a bent valve...check the condition of the brass orings in the exhaust ports which seal the head pipes to the cylinder head. Good luck.
I'm hoping exhaust leak as well. It's got 8 brand new Kibblewhite stainless steel valves, was vaccum checked after recutting the seats - it definately can't be a bent valve.
The builder gave me a list of clearances. 6 are .004 and two are .005 - spec for I/E are the same .002-.006.
It has to be an exhaust leak. C'mon 5 o'clock I want to get home and find out!!!
- kano
- Not Another Bloody Limey!
double up your exhaust gaskets
if you used new ones,
- sheik*yerbouti
exhaust leak did you use the old ones?
Nope used new ones. And actually through my excellent rapport with Rob @ Z1Ent., and him asking at one point if I was doubling up the copper crush OEM type gaskets as I had asked for 8 - he recommended I get the model shown below instead as it is 5mm thick instead of 3mm.
I do have two more full sets of the thicker, and if I find the leaking pipe, I will double it!
I use:
www.z1enterprises.com/detail.aspx?ID=1602
-instead of-
www.z1enterprises.com/detail.aspx?ID=196
