2nd start post rebuild - obvious ticking noise vid
  • sheik*yerbouti
  • Topic Author
29 May 2009 10:23 #294825 by sheik*yerbouti
At work will monitor thread no time to type now but will after lunch.
Discuss!
29 May 2009 10:36 #294827 by Buda
:blink: No vid
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Vance&Hines pipe with comp baffle
dyna coils and wires
97 Valkyrie Standard
  • sheik*yerbouti
  • Topic Author
29 May 2009 10:44 - 29 May 2009 10:47 #294831 by sheik*yerbouti
Replied by sheik*yerbouti on topic 2nd start post rebuild - obvious ticking noise vid
Last edit: 29 May 2009 10:47 by sheik*yerbouti. Reason: redid url
29 May 2009 10:55 #294833 by Buda
Is there exhaust on that engine
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
29 May 2009 10:55 - 29 May 2009 12:58 #294834 by Jack
Sounds like an exhaust leak to me. Much easier to remedy than a bent valve...check the condition of the orings in the exhaust ports which seal the head pipes to the cylinder head. Good luck.
79 KZ 1075 MKll
79 KZ 1500 MKll dragbike
Gone but not forgotten:
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
Last edit: 29 May 2009 12:58 by Jack.
29 May 2009 10:56 - 29 May 2009 10:58 #294835 by Buda
Thats what I was gittin at. I had that same kind of ticking sound when I first started my bike after haveing the head off this past winter, it turned out to be an exhaust leak.
Tom
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Last edit: 29 May 2009 10:58 by Buda.
  • The Garbone
  • User is Currently waiting for his bailout check..
29 May 2009 10:59 #294836 by The Garbone
Replied by The Garbone on topic 2nd start post rebuild - obvious ticking noise vid
:huh: It is a bit loud for a bike with pushrods and since it has OHC I think your have a exhaust valve issue on your #1 or #2 cylinder.. Too much gap or not seating 100%?
2007 Royal Enfield Iron
1979 KZ650 & Hack
1949 Ford 8n
  • sheik*yerbouti
  • Topic Author
29 May 2009 11:52 - 29 May 2009 11:53 #294839 by sheik*yerbouti
yup a MAC 4-into-1 slash just behind the collector like a modern MotoGP look... loud!
Last edit: 29 May 2009 11:53 by sheik*yerbouti. Reason: forum fail
29 May 2009 12:15 #294841 by Buda
I couldnt see any exhaust in your vid. :blush: I thought at first, like you that the sound your hearing was coming from the valve train, then I noticed one of my split collars wasnt seated.
Tom
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
  • sheik*yerbouti
  • Topic Author
29 May 2009 12:43 #294845 by sheik*yerbouti
Jack wrote:
Sounds like an exhaust leak to me. Much easier to remedy than a bent valve...check the condition of the brass orings in the exhaust ports which seal the head pipes to the cylinder head. Good luck.
I'm hoping exhaust leak as well. It's got 8 brand new Kibblewhite stainless steel valves, was vaccum checked after recutting the seats - it definately can't be a bent valve.
The builder gave me a list of clearances. 6 are .004 and two are .005 - spec for I/E are the same .002-.006.
It has to be an exhaust leak. C'mon 5 o'clock I want to get home and find out!!!
  • kano
  • Not Another Bloody Limey!
29 May 2009 12:50 #294846 by kano
exhaust leak did you use the old ones?
double up your exhaust gaskets
if you used new ones,
  • sheik*yerbouti
  • Topic Author
29 May 2009 13:34 #294848 by sheik*yerbouti
Nope used new ones. And actually through my excellent rapport with Rob @ Z1Ent., and him asking at one point if I was doubling up the copper crush OEM type gaskets as I had asked for 8 - he recommended I get the model shown below instead as it is 5mm thick instead of 3mm.
I do have two more full sets of the thicker, and if I find the leaking pipe, I will double it!
I use:
www.z1enterprises.com/detail.aspx?ID=1602
-instead of-
www.z1enterprises.com/detail.aspx?ID=196
