- Thank you received: 22
re-torquing head
- GPz550D1
Robert
1981 KZ550-D1
- Pro_window78
- gane
- Thank you received: 1
[img][/img] 1977 KZ1000A1
- dman3998
It is possible to get oil from under the head nuts as well. They have copper crush washers, under them to help seal them..
U loosen the nuts a 1/4 turn , 1 at a time, to relieve stress and retighten. this give a more accurate torque.
i remove then 1 at a time and apply some high heat silicone under the nut and washer,to help seal them, just in case. I hate leaks.
The silicone acts as a lubricant and reduces friction during the torque. this give a more accurate torque .
But i like to go overbored sometimes too.
need to be careful on this, some specs are wet and some are dry if the spec was dry and you lube the threads you could over torque and strip out something. I assume its its dry unless specifically listed as wet or lubed.
dman
Dman
SE Idaho
"Smart only goes just so far, STUPID is UN-limited"
79 KZ1000 LTD
Honda XRL650L
Yamaha RD350B
Yamaha DT400B
- mark1122
- Keep twisting it
- Thank you received: 109
Have u ever read a % dif from dry to wet?
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- Dragone
dman
exactly. Especially since all of the bolts are grade 2 and will stretch badly as it is.
- mark1122
- Keep twisting it
i have never stripped a bolt.i have of course stripped a hole thread. but only the usual ones that everyone stripps, like the cam caps.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
