re-torquing head
- alexgehrig
I've got an 80 kz650 with 13k leaking oil from what appears to be both the head gasket (front of engine) and base gasket (#1 cylinder area).
- Thank you received: 2098
Good Luck!
- alexgehrig
THoughts?
Could clean engine and get it completely dry, then spray foot powder around the potential leak areas, start the engine and watch closely to find exact source of leak.
Good Luck!
One other point - to loosen or not to loosen. I've seen some folks say they just set the wrench and tightened and others have loosened (1/4 turn) and then re-tightened.
THoughts?
Can't really explain why, but I like to first just set the wrench and attempt to tighten. Then when it doesn't move, loosen it the 1/4 inch and re-torque.
Good Luck!
- TeK9iNe
- What did you do!?!
- Thank you received: 28
Its apparently the oly way to achieve the higher torque setting.
Whatever works.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- GPz550D1
- Thank you received: 22
I've seen a few discussions here and there, just wondering what results people have seen with re-torquing head nuts to slow/stop leaks.
I have a '81 Gpz550 that was leaking oil towards the center of the engine. Tried to re-torque head nuts and they were all tight. Then I marked the nuts location in relation to the head and loosened each nut 1/4 turn and then torqued to specification. Each nut tightened down 1/8 to 1/4 more of a turn compared to where they were originally. I don't see how the head gasket hadn't blown before this. Oil leak has stopped for the moment and hopefully for a long time. This was done several years ago and my bike has 21,000 miles on it now.
Robert
1981 KZ550-D1
- Thank you received: 2829
Did you loosen all nuts 1/4 turn first before re-torquing or did you loosen and re-torque each nut one at a time?
- GPz550D1
GPz550D1 wrote: "Then I marked the nuts location in relation to the head and loosened each nut 1/4 turn and then torqued to specification."
I did them one at a time, following the torque sequence that the manual calls for.
1981 KZ550-D1
- alexgehrig
My instinct tells me to loosen everything 1/4 as you would if you were removing the head (following proper sequence)and then tighten accordingly.
Thoughts (anyone)?
- bountyhunter
- Thank you received: 337
- mark1122
- Keep twisting it
- Thank you received: 109
U loosen the nuts a 1/4 turn , 1 at a time, to relieve stress and retighten. this give a more accurate torque.
i remove then 1 at a time and apply some high heat silicone under the nut and washer,to help seal them, just in case. I hate leaks.
The silicone acts as a lubricant and reduces friction during the torque. this give a more accurate torque .
But i like to go overbored sometimes too.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
