- Thank you received: 12
Time for a new exhaust?
- clutch
- I wish I had a tad more patience to do it better!
clutch wrote:
...Throttle cable is definitely not the issue. I'm thinking it may be something sticking open on a carb or two. If say for example I am at a red light and the idle hangs a little high on me, I will squeeze the front brake and let the clutch out just a bit and it will drop back to normal....
Likely air leak through crack in deteriorated carb holder or old hard vacuum plug, or maybe just a loose clamp at carb>holder, or leak in vacuum tube from carb to petcock if so fitted, or loose fit where carb holder attaches to engine. And maybe some other place escaping me at the moment.
Good Luck!
Well I've sprayed all the rubber with starting fluid with no change in idle...I guess I will have a look at that vacuum hose and plugs next.
Thanks for the replies guys!
~Clutch
Southern Maryland, USA
1980 KZ250 LTD (traded, but still missed)
1982 KZ750 E3 (Cafe Project) (Dyna-S, Dyna Coils, V&H 4-1, K&N Pods, 6 Sigma Jet Kit, Acewell Computer, Woodcraft Clip-ons, Custom Rewire)
1966 A1 Samurai (Restoration Project)
Wish List:
KZ1000 P (For a "touring" bike)
Z1 (need I...
- Thank you received: 2098
Visual inspection is also needed on the vacuum caps and vacuum hose, especially to assure no cracks anywhere in hose and good snug fit of hose at carb nipple and at petcock nipple.
Good Luck!
Am wondering about possibility of advancer tending to hang in advanced position rather than immediately returning to idle position. Perhaps a cleaning and lubing of the advancer could be helpful.
Good Luck!
Good Luck!
- Kingchiefa
- To each thier own.
You should look into the vance and hynes 4 in 1 exhaust if you don't already have it. I don't know how much they cost mine was on when I bought the bike. I know Z1 carries them check it out.
1979 KZ1000 ltd b3 Currently in Troy, PA. Hope to some of you on the road.
- clutch
Hey Clutch,
Z1 Apparently doesn't carry them anymore. I did find them listed on BikeBandit.com for a little over $300. I hear good things about the Vance and Hines, but I see a Mac system that I like the look of a little better. Does anyone know of this system? Is it worth getting, or should I go for the Vance and Hines system? Here's a link to the Mac:
www.bikebandit.com/product/12772?mg=5098&t=1&td=1
Wish List:
Z1 (need I...
- clutch
Oh! I almost forgot. Another of my previous posts had mentioned a hanging idle and someone suggest looking at vacuum lines and such. When I pulled the vent valves to replace the valve cover gasket, I noticed they were cracked. Could this be the culprit? Please tell me yes so I can think it's an easy fix! LOL!
~Clutch
Wish List:
Z1 (need I...
...my previous posts had mentioned a hanging idle and someone suggest looking at vacuum lines and such. When I pulled the vent valves to replace the valve cover gasket, I noticed they were cracked. Could this be the culprit? Please tell me yes so I can think it's an easy fix! LOL! ~Clutch
Yes!
Good Luck!
- clutch
Thanks guys,
Clutch
Wish List:
Z1 (need I...
- oldkaws4ever
- Have no regrets...... You only live once.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- clutch
Wish List:
Z1 (need I...
- oldkaws4ever
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
