- Thank you received: 10
head porting
- timebomb33
I THINK MY POWERBAND BROKE
- PLUMMEN
- Thank you received: 104
- timebomb33
- larrycavan
- Visitor
i'm just starting porting one of my extra gpz heads for one of my 1393 blocks i'm going after some big flow numbers on this one i'm using .507 lift cams and i'm planning on a big load of nitrous going thru this motor i'm aiming for low 8's possibly 7's on a 7 inch tire. i think i can do it to morrow i driving the guides out and going crazy on the head. i'm putting in shorty guides[another fine product from ape] i already have my nitrous ports set up and ready to go so that is figured out next i have to get some good epoxy so i can start raising the floors up i don't have over size seats so all i can do is go to oversize valves but it will work the intakes are going to be matched up to a set of 40 mm lectrons. as soon as that head is done then i start on another head for my little bike, one that will work on a 1197 block so that little 5.5 tire will be working hard. larry help me out what kind of epoxie are you using i used to use devcon but i'm having a hard time finding it.
If you're going to fill the ports, Joe Mondello has what you're after. 1-800-MONDELLO (666-3355)Spalsh Zone Pro Epoxy Kit
Get some Kay Rolls while you're on the phone with them. They're great to have around the shop for more than just porting.
IMO, you're ahead of the game if you have a J head to start with. Port volume / runner CSA is more appropriate for what you're building with a whole lot less grinding.
Larry C
- PLUMMEN
you and larry are da man,or da men! :woohoo: :laugh:yes your exactly right mr.plummen dood if i didn't know what iwas doing and didnt have accsess to flow benches and accsess to an engine dyno and two 250i chassis dyno's id never attempt it but since i do i'm going freakin crazy i work in the worlds best place to be a motorcycle mechanic with the summers off it's incredable i feel like a little kid at disney land sometimes buddy it's awesome. i have ported quite a few heads for some the local smaller engine guys and more than a few for my self but i've never done a real go fast head so now's the perfect time to do it.and your right you can mess up real bad if your not carefull as for larry i have heard nothing but good things about his work and if i wasn't working where i am i would have absolutly no problem giving him my stuff to do the man is a pro and highly respected all over not just here. infact one day maybei'll get him to do one up for me as well just to see how i stack up it would be worth it.
- Thank you received: 797
leon holmes
keep us posted timebomb,there seems to be lots of interest in portwork.
leon holmes
- APE Jay
- Banned
- Thank you received: 58
Larry C
X2
- timebomb33
- larrycavan
- Visitor
it's not the grinding i'm worried about it's the filling back in when i've gone to far!
Lot's of material in those heads.
Probe it while it's on the bench at .400" lift @ 28" with the carbs mounted on the head. Need a good J bend pitot? Holler and I'll put you in touch with a guy. He's made several for me. He's a disabled veteran, super nice guy and all the extra work he gets really helps him out.
Larry C
- timebomb33
- judgie
do you steer the airflow to one side of the port to create swirl into the chamber or just go for the best flow into the seat area.
i know what works on the vw aircooled heads i work on but the small high rpm bike heads are a new learning curve.
theres a lot of differance to getting a head to flow for 500cc per cylinder at 6500rpm than a 165cc cylinder at 10000rpm.
forever tweeking aircooled engines, well it is my job
77 z650c1
