- Thank you received: 235
can a head gasket not run be r &r once
- trianglelaguna
...my stupid question is....can i take the motor apart again and re-use this cometic head gasket if i have not ran the motor with this h-gskt or retorqued again......i wanna do the whole thing over and do some different timing roller replacment....and will just buy another 72mm gskt if need be....thanks no exp here so thought i'd ask you guys....thanks
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
- jzanutto
I guess if the first time you torqued it you were at the minimum torque, and if the second time you torqued it to the max value then maybe you could crush it further and it may seal.
roll the dice....
1978 KZ650B 2004 BMW R1150RT
- dman3998
of course there is the PITA factor. To replace a head gasket on a 2 stroker is like maybe 10 mins tops. for the KZ its a little more involved. may not be worth taking a chance.
Dman
SE Idaho
"Smart only goes just so far, STUPID is UN-limited"
79 KZ1000 LTD
Honda XRL650L
Yamaha RD350B
Yamaha DT400B
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
- trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
- timebomb33
- dman3998
Quench or not to Quench in water? Apparently makes no difference to the copper. will be annealed either way
The copper is hardened by compressing it or working it not the temp that it gets to by what ever it is sealing.
mute point if your gasket is a fiber/metal crush to seal type anyway. I would get a new one.
Dman
SE Idaho
79 KZ1000 LTD
Honda XRL650L
Yamaha RD350B
Yamaha DT400B
- Old Man Rock
- Thank you received: 225
There's enough crap in rebuilding these old beauties to drain the brain over and this should not be one of them...
Just think how pissed off you're going to be if you don't and you go through everything required to put her back together & first start and you find an oil leak!
Just my worthless 2 cents....
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- nads.com
- Thank you received: 20
- bountyhunter
- Thank you received: 337
hey so i torqued my z-1 motor and set everything and all seems good turns over and timing on cams is good motor is smooth turning...tdc right..tensioner re-set...ect..
The official answer is NO. That said, I did it last time I put my motor together. The base gasket failed after about 100 miles of running and I had to tear it apart again... The head and cylinders were perfectly smooth and the head gasket looked fine, so I reused it and it has worked perfectly.
Obviously, it would have been better if I had a new one, but they are not easy to find on old twins and I didn't want to wait another two weeks.
- bountyhunter
In reality, head gaskets MUST "crush again" because they need a second torquing after they run in. I figured the reuse torque was just like a second torque anyway.I resuse gaskets all the time and never had one leak. I just wouldn't reccommend it to anyone else. Only gasket I won't reuse is a water cooled head gasket. All you people out there saying the crush the crush? It crushed it once didnt it? Why won't it crush again?
