Ticking on #1
- sbulla
- 1980 KZ1000 LTD
Could this be piston slap? Tear down or keep riding and monitoring?
Sonny
Now----
1980 KZ1000 LTD (Kerker 4-1, K&N pods, Dyna gray coils)
Gone but not forgotten----
1966 Honda 305 Superhawk
1969 HD 350 Sprint
1971 500 H1
1972 250 F8
1972 750 H2
1973 KX250
1995 HD Sportster 1200
2000 HD Softail
2002 KLR650
- Thank you received: 2098
Could be loose nut on exhaust clamp stud or need to replace copper exhaust gasket.
If any doubt, would double-check valve clearances, especially exhaust valve on #1 cyl.
Also, with cold engine, could re-torque head bolt nuts to possibly correct a leaking head gasket.
Good Luck!
- Old Man Rock
- Thank you received: 225
... Ditto on that!slight leak where exhaust header pipe connects to cylinder head.
I had the same on cylinder #4, brand new motor re-build and new Kerker... Slight tick-tick-tick.... Equating to exhaust leak... Permatex both sides of the copper exhaust washers, re-postion the Kerker header tubes and re-trogue down, all good no ticky!
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- bountyhunter
- Thank you received: 337
- bountyhunter
The right hand side of my twin REQUIRES two copper donut washers to seal, it absolutely won't seal with only one. Check the washers for black blow by and if they are not sealing, you may want to double up on the leaky spot. I'm not sure gasket sealer will last in such a hot area, maybe but it would worry me.I had the same on cylinder #4, brand new motor re-build and new Kerker... Slight tick-tick-tick.... Equating to exhaust leak... Permatex both sides of the copper exhaust washers, re-postion the Kerker header tubes and re-trogue down, all good no ticky!
OMR
- Old Man Rock
Whoa, is that OEM requiring two washers per header exhaust or just your situation?
I was speaking of my KZ900 so sorry if miss understood...
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- kano
- Not Another Bloody Limey!
im not a mechanic im a carpenter!
- sbulla
- 1980 KZ1000 LTD
I'll double check the seal on that pipe as I just re-installed the header with new gaskets yesterday after making some modifications to the Kerker. I do have some thicker gaskets I got from Z1E, maybe I'll try it on that one pipe.
Thanks for all the replies,
Sonny
Now----
1969 HD 350 Sprint
1971 500 H1
1972 250 F8
1972 750 H2
1973 KX250
2000 HD Softail
2002 KLR650
- bountyhunter
All I know is, the right side exhaust will leak if I don't double up on the donut washers on that side.REQUIRES two copper donut washers to seal
OMR
- Old Man Rock
If you look at them real closely, you'll find one side is flat while the other has a rounded bevel on it....
The flat side goes to the head to seal while the round side goes to the exhaust header pipe!
NOTE: Or do I have that backwards.... :laugh:
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- franknsr
Oh crap, almost forgot another thing about the washers...
OMR
Hmm, that could explain MY ticking noise on #4....or not.
Formerly CSRchopper
1991 KZ1000P
1986 ZG1000
1982 650 CSR -shoulda kept this one-
Lisle Illinois, USA
- sbulla
- 1980 KZ1000 LTD
I went out and loosened up the #1 exhaust header and noticed it moved just a bit. I wiggled it and felt it seat onto the gasket, held it there tightly, re-tightened the collar, and now, all is good....no ticky!
Thanks guys,
Sonny
Now----
1969 HD 350 Sprint
1971 500 H1
1972 250 F8
1972 750 H2
1973 KX250
2000 HD Softail
2002 KLR650
