- Thank you received: 797
that's some head!
here is what the fellow said about it.
REPLIKAMASCHINEN HEADWORK REVEALED-- A few pictures of the old style PSM 1550 cylinder head that I had been working on. I have flow tested, re-contoured, installed new guides and cut new seats, etc.
--Don
leon holmes
- tachrev
- Rubber Side Goes Down
- Thank you received: 11
:ohmy:
Build Thread
leon holmes
- StreetfighterKz
- Thank you received: 117
Later, Doug
1978 z1000 Streetfighter
1976 z900 Stripfighter (work in progress)
1983 Gpz750 Resto-Mod
1989 Vmax
- eruhf
1977 KZ1000
1980 KZ1000 LTD - '76 900 motor
i think it would be mostly air to try that with a stock casting.
leon holmes
- Jack
If you look really close at the bottom right hand corner of the 2nd pic it looks like "VHMS" is stamped into the casting meaning it's an aftermarket head. Did you also notice the GS style intake boots as opposed to the normal 2 bolt Kz style boot?
Later, Doug
Looks like a V & H head to me. Quite common to do the Zuk boots/intake to PSM heads.The intake runners also have a straighter shot to the combustion chambers, I know a couple of people who have done this mod to Kaw heads- good machinists & fabricators.
79 KZ 1075 MKll
79 KZ 1500 MKll dragbike
Gone but not forgotten:
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
- larrycavan
- Visitor
160CFM@10"
Your street ride can't use it for several reasons. For serious drag racing only.
Larry C
- kzz1p
- One Test Is Worth A Thousand Expert Opinions!
- Thank you received: 3
Is that the old MTC design? If so, was it taken over by Ward?
- bigwill5686
77 kz1000 ltd- 4 into 1 kerker, 1075, dana ignaiton, cams and carbs and head work done...
1999 busa- 4 into 1 yokomo, k&n intake, power comander.....
- APE Jay
- Banned
- Thank you received: 58
These heads have the valve angles spread so they can get 46/38mm valves in it.
This means they can only be used with 85 mm bores. We did one kawasaki at 84, but the intake valve pocket on thew piston almost went into the top ring land.
These heads could not be used on the street because the ports are so large that the motors won't hardly run under 8000 rpm. Racers using these heads leave at 10,000 and shift at 13,000. Valve springs are good for the entire weekend.
Jay
