- Thank you received: 2829
Troublesome Oil Leak After bolt falls out!
- hoghaterkaw
- Thank you received: 1
- clutch
- I wish I had a tad more patience to do it better!
- Thank you received: 12
Do you think it was filled all the way up to the crankshaft at the level of oil stain in under the points cover? If so, you may find you don't have a leak problem at all once you clean things up and put the correct amount of oil in the engine. Ed
It is possible. If you notice the oil window in the pic, I have corrected the oil level issue. I pulled the plug and replaced it when the oil level dropped to within spec. I am not sure if the level was quite that high, though I will take your advice, to clean it up and ride it.
I did do a quick wipe job earlier (with just the cover off) and started the bike back up after draining some oil. It still dripped, though not as much. It could have just been run off from the previous level issues, but I kind of doubt it. Anyway, I may throw it back together tonight and go for a ride, if not, I will tomorrow. Either way, I will post to let all know.
~Clutch
Southern Maryland, USA
1980 KZ250 LTD (traded, but still missed)
1982 KZ750 E3 (Cafe Project) (Dyna-S, Dyna Coils, V&H 4-1, K&N Pods, 6 Sigma Jet Kit, Acewell Computer, Woodcraft Clip-ons, Custom Rewire)
1966 A1 Samurai (Restoration Project)
Wish List:
KZ1000 P (For a "touring" bike)
Z1 (need I...
- clutch
So, my favorite motorcycle gurus, do I need to replace the part, or is it something that I can fix? I'm hoping it is fixable so that I can ride again soon without oil splatter, and not have to pay for a new part. But, either way I at least know that I will be fixing the issue and not wasting time on an educated guess.
Thanks again for all the support guys,
~Clutch
Wish List:
Z1 (need I...
- clutch
~Clutch
Wish List:
Z1 (need I...
- bill_wilcox100
- Thank you received: 5
If the thread is the same size, then is the dial assembly small enough to fit in there with the timing plate and can you get the cover back on to protect everything in there.
For me, no pressure alarm is a show stopper. These engines will last decades and decades as long as you have oil. Just my 2 cents worth, It's your bike and your choice.
Best of success.
Bill
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
- hoghaterkaw
- Bluemeanie
- Thank you received: 14
- clutch
if it were up to me, i would just get a new stock OEM pressure switch.
Any ideas where to get one cheap? I found one on ebay for about $50 including shipping and that seems to be the lowest price around!
~Clutch
Wish List:
Z1 (need I...
- clutch
~Clutch
After searching a little more, I just went with the one on eBay. They have one more listed if anyone is looking for this part as well! Part # 16144-006
Wish List:
Z1 (need I...
- oldkaws4ever
- Have no regrets...... You only live once.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- clutch
Hey clutch, glad your problem was the oil pressure switch and not the crankshaft seal, the crank seal would have been a royal PITA to fix.
Me too! To prevent myself from riding with the leak while I wait for the part, I started prepping/painting the fenders, side covers, 1/4 fairing (emgo viper), and gas tank....but that will be a different thread. LOL!
~Clutch
Wish List:
Z1 (need I...
