- Thank you received: 12
Troublesome Oil Leak After bolt falls out!
- clutch
- I wish I had a tad more patience to do it better!
I went for a ride today, and after a few minutes I noticed both my right shoe and right footpeg were covered with a fair amount of oil. I cannot figure out for sure where it is coming from and am hoping that one or more of you may have some suggestions for hunting down both the leak and the bolt's home.
Thanks in advance,
~Clutch
Southern Maryland, USA
1980 KZ250 LTD (traded, but still missed)
1982 KZ750 E3 (Cafe Project) (Dyna-S, Dyna Coils, V&H 4-1, K&N Pods, 6 Sigma Jet Kit, Acewell Computer, Woodcraft Clip-ons, Custom Rewire)
1966 A1 Samurai (Restoration Project)
Wish List:
KZ1000 P (For a "touring" bike)
Z1 (need I...
- clutch
1. Oil leaks only when bike is running
2. Drain plug is accounted for
3. When on sidestand, oil drips off peg, but not from anywhere else that I can tell
4. I'm not 100% sure the bolt even came from the bike! :huh:
Wish List:
Z1 (need I...
- apeman
- Thank you received: 3
Petaluma and Truckee, CA -- member since Jan. 23, 2003;
PREVIOUS KZs: 1980 KZ750H with 108,000 miles; 1980 KZ750E with 28,000 miles; and KZ750H street/cafe project, all sold a few years back.
This is what I do for fun, not for work. It is art, with a little engineering thrown in.
- donthekawguy
- Thank you received: 8
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
- l0g1c
- Hanging on for dear life.
Just repeating some advice I've seen here, already.
'81 KZ750 LTD
'72 CB350K
Omaha, NE
- clutch
So next, I decided to put the bike on the centerstand and start her up. Within 30 seconds, I noticed a steady drip from the bottom of the timing advancer cover (not sure if that's the name of the cover). After closer inspection, I noticed a small round hole just forward of where the wire/cable comes out of the bottom. It looks like it should have some kind of plug or screw to prevent the oil leak, unless it's an overflow of some kind and there's too much oil in the bike. Anyway, it is the perfect spot for wind to blow the oil back onto my foot/footpeg.
Any ideas on plugging this leak???
ps: the bolt appears to be a motor mount bolt that I will stop by Lowes to replace the missing nut!
Wish List:
Z1 (need I...
- clutch
Wish List:
Z1 (need I...
- hoghaterkaw
Ok...just went out to the other garage to look at the spar engine I have....same hole...no plug/screw.....any ideas? I'm really starting to think this IS an overflow and there is way too much oil in the bike (though checking the window it looks fine when running)!!!
the oil level is checked with the motor off. also give the oil some time to drain down before checking the level. if you can see an oil level in the window while the motor is running then your way over filled.
- hoghaterkaw
- clutch
So...I'm guessing that I was correct in my assumption that the hole is some kind of overflow...which means that the previous owner put way too much oil in. It's a little strange that I hadn't noticed the leak before...perhaps I hadn't taken a long enough trip to notice much of anything.
Definitely time for an oil change then!
Wish List:
Z1 (need I...
- clutch
oh BTW the timing cover should not have oil in it. you may have blown a seal.
:ohmy: Ok....guess I need to check that out too then!!!!!!! :ohmy:
Wish List:
Z1 (need I...
- bill_wilcox100
- Thank you received: 5
The points cover has two groves:
1) As you have already noticed, one for passing the ignition timing wires and oil sending unit wire (at least that's what I see in my KZ650-B1).
2) The other very small one for venting and draining to counter the effects of condensation.
As you have been advised, there should be NO OIL in this compartment. If there is, it could be coming from one of two and ,less likely, three places:
1) The oil pressure sending unit. If so, check gasket or O-ring (don't remember which) and re-tighten. You may need to change the sending unit or plug it temporarily with a bolt.
2) Crank end oil seal. Change the seal (I have never done this so no advise here).
3) The upper and lower cases meet here too. Could be the gasket... that's a whole other animal (again, no advise here.)
The Vent
Best of success.
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
