- Thank you received: 1
Valve Clearance Check Questions...
- zoro
GHOSTRIDER,1980,KZ1000ST
- gane
[img][/img] 1977 KZ1000A1
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- zoro
Will Do! Thanks for the response and info Timebomb!also one other thing depending on how the shims have been installed the numbers might be wiped off ,also never trust the numbers anyway make sure you measure each shim with a vernier caliper to verify size and markdown that shim size and what bucket it came out of before you start your calculations shims usally come in half sizes 200-205-210 and so on so that is 2.00mm-2.05mm-2.10mm a half size is roughly .002" differance. so take your time double check when you are done roll it around and check again.
- timebomb33
- 79MKII
- Love Them Kaws!
- Thank you received: 43
Here's a pic of the damper bracket. The bracket is a "T" and mounts where the old reflector went. There is probably a better way but this is what I ended up with...
The Kaw List:
