- Thank you received: 3
1000 pistons.......do I need to sleeve?
- z19OO
When you say bracket bike. Are you saying "bracket bike ridden on the street" or "bracket bike only"? Then I would ask, how fast? Big budget or small?
Probably street and track use. I'd be happy to get 10's in the 1/4. I have a small budget but have lots of parts from collecting over the years.
1975 z1 900
1979 kz650b
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- kzz1p
- One Test Is Worth A Thousand Expert Opinions!
What piston sizes do you have? (if any) What size cams do you have? (if any)
- z19OO
I have some used 1105 Wiseco's & these new HA 1000 pistons that I know of. For cams, I have Andrews 2x and some monster unknown cams. They are in a kz900 with lots of aluminum removed for clearance + has shim under buckets. Largest carbs are 34cv's & 29 smoothbores.
1975 z1 900
1979 kz650b
- kzz1p
The Andrews 2x (.360"/258*@.030") with the 1000cc or 1105cc pistons and 29mm carbs, would make a very nice streetable bike. Those are small mid range cams that, could use shim on top buckets. The 29's is all the fuel you will need for either motor. You could build something simple and nice, at a low price and enjoy it for years.............
PS- The andrews cams with the 1000cc pistons would put you close to the low 11's, and with the 1105cc pistons, maybe high 10's (with good riding skills and tuning)
- z19OO
1975 z1 900
1979 kz650b
- timebomb33
- kzz1p
Road race/Drag race, use 12:1 or more compression. Full power top end, some added mid range. Shim on top okay...
It doesn't sound like they are for street use. The loss of botton end and some midrange, may not benifit you......If you want to race, add more compression and head work.
