- Thank you received: 3
1000 pistons.......do I need to sleeve?
- z19OO
1975 z1 900
1979 kz650b
- Thank you received: 797
- z19OO
1975 z1 900
1979 kz650b
leon holmes
- z19OO
1975 z1 900
1979 kz650b
- PLUMMEN
- Thank you received: 104
leon holmes
p.s. i copied and pasted this from wiseco's website.they are not clear on the 1045 as they don't say that you have to sleeve for those,but they offer a sleeve at the bottom.for the 1075 they clearly state re-sleeve for 900's.hth
Base gaskets and sleeves are supplied as noted
1015cc 2.756" or 70.00mm K1015 10.25:1 Cylinder boring only for KZ900 Drop in kit for KZ1000
Standard for KZ1000 $678.37 Piston: 4020M07000 $152.00 Rings: 2756XC Piston Pins: S523
4mm oversize for KZ900 Retainer Clips: CW17 CFM20 Head Gasket: W3917 $56.05
Stroke - 65.93mm Fiber Base Gasket: W5380 $14.32 Optional: Sleeve: KA627SL, 3099FA
1045cc 2.795" or 71.00mm K1045 10.25:1 Cylinder boring only
1mm oversize for KZ1000 $678.37 Piston: 4022M07100 $152.00 Rings: 2795XC Piston Pins: S523
5mm oversize for KZ900 Retainer Clips: CW17 CFM20 Head Gasket: W3917 $56.05
1075cc 2.835" or 72.00mm K10741 9:1 Cylinder boring only Resleeving required for KZ900
2mm oversize for $638.53 Piston: 4379M07200 $142.04 Rings: 2835XC Piston Pins: S523
KZ1000 Retainer Clips: CW17 CFM20 Head Gasket: W3918 $56.05
- APE Jay
- Banned
- Thank you received: 58
- Old Man Rock
- Thank you received: 225
In researching this very same issue in my project, pretty much everyone (known engine builders) I spoke to replied the same... 1045 in a 1000cc cylinder, bore & hone only...
In a 903cc cylinder, sleeves required but you will be on the thin side... In Arizona summer heat, thin not a good option...
Here's another thing to think about as in my case, I had broken cylinder fins so instead of paying over priced fin repairs, obtain one of the over stocked parts galore kit (cylinder, Wiseco pistons, rings, pins, clips included)... 1015, 1045, 1075...
Now this was an interesting option.... 1045, hmmm.... Here's the thing though, I would need to enlarge my top lower case cover for the bottom of the cylinder sleeves
to fit into, just like I would need to do with the 1075 cylinder...
At which point I figured, what was it worth to me like 1015cc with my CAM & carb selections wasn't enough.... Naw, didn't want to go there, especially after what I went through with MRE who does the machining for overstock... No thanks, 1015cc was more than enough power....
Just my 2 cents worth....
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- kzz1p
- One Test Is Worth A Thousand Expert Opinions!
- PLUMMEN
- Old Man Rock
there's plenty of hard running small motors out there,it comes down to whether or not you know how to put it to the ground.
Quote from Larry C when doing my research into what performance I was looking for.... I guy in his area had a 1045cc motor, forget which cam & carb setup but said the guy was untouchable for many seasons...
Basically was kickin the crap out of everyone with that little motor setup... Big 1075's & huge CAM/carb guys just couldn't figure it out on how this little motor was cleaning their clocks.... :laugh: :laugh:
Outside of our wives/GF's, bigger is not always better!
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
