- Thank you received: 1
i found this in the bottom of my oil pan!
- EricHa
23 Feb 2009 06:46 #267438
by EricHa
1977 Kawasaki KZ900A5
1975 Honda CB550K
1996 Ducati 900SS CR
Replied by EricHa on topic i found this in the bottom of my oil pan!
donthekawguy wrote:
Yep, and I believe that the cam chain guide has a small metal plate inside the plastic/rubber body. Also, those rubber pieces get rock hard over 30 years.
Probably part of the cam chain guide. Pretty common on the older 1000's and 900's.
1975 Honda CB550K
- wiredgeorge
23 Feb 2009 12:46 #267500
by wiredgeorge
Replied by wiredgeorge on topic i found this in the bottom of my oil pan!
EricHa, He has a J motor bike with a different type cam chain bumper in the front. I am not sure that there is any metal in the thing you have pictured anyway. I have had them broken right up to the fingers that fit in the slot... the end the screw goes in is metal but you are looking at all of the metal in the picture and it can't come loose because of the M5 screw.
Kano, I don't recognize that thing... it isn't a key from the keyway on your stator as that isn't as big and is shaped differently as I recall... It probably fell in when the valve cover was off. I don't recall a part of that sort coming from inside the engine but could be wrong as I don't work on nearly as many J motors.
- EricHa
23 Feb 2009 12:54 #267502
by EricHa
1975 Honda CB550K
wiredgeorge wrote:
EricHa, He has a J motor bike with a different type cam chain bumper in the front. I am not sure that there is any metal in the thing you have pictured anyway. quote]
Whoops, an ELR. My bad. I do believe that there is metal inside the Z1 guides, but I have been wrong before.
1975 Honda CB550K
- mark1122
- Keep twisting it
- Thank you received: 109
23 Feb 2009 15:23 - 23 Feb 2009 15:24 #267536
by mark1122
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Replied by mark1122 on topic i found this in the bottom of my oil pan!
Could it be from somewhere in the the clutch basket area? the J's baskets are aluminum arnt they.
How about the back of the basket where the springs go in , is there anything that shape back there?
How about the end of the cam chain tentioner? the kz has a metal pad on the end ,how about the J's?
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 23 Feb 2009 15:24 by mark1122.
- kano
- Not Another Bloody Limey!
23 Feb 2009 16:18 #267548
by kano
Replied by kano on topic i found this in the bottom of my oil pan!
had the clutch apart yesterday all is well there,
replaced the springs for some ape one's i just got and buttoned it up.
this weekend ill take off the rocker cover see if all is well there.
plus have a ape cam tensioner on its way.
bike isn't going anywhere for a few weeks anyway.
on close inspection the piece of metal has a even wear mark about a 1/8 on both ends.
but is not damaged in anyway,
so if it did come down through engine it dropped right through not damaging anything on its journey.:huh:
- mark1122
- Keep twisting it
24 Feb 2009 07:19 #267724
by mark1122
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
would the ware marks hapen to corraspond with the width of the cam chain?
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
