The best OIL to use!
- Darkangel
21 Feb 2009 21:43 #266976
by Darkangel
_________________________________________
1983 Kawasaki KZ 1100 A2 - streetfighter
The best OIL to use! was created by Darkangel
What do you guys think is the very best oil to use in our bikes? I currently have a 83 KZ 1100.
- Buda
21 Feb 2009 21:53 #266985
by Buda
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Vance&Hines pipe with comp baffle
dyna coils and wires
97 Valkyrie Standard
Replied by Buda on topic The best OIL to use!
castrol gtx is what I use
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
- timebomb33
- Thank you received: 10
21 Feb 2009 21:57 #266988
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic The best OIL to use!
use a good grade of motorcycle specific oil [ convential type not synthetic] look for the api rating on the back of the bottle look for sg or sj rated oils don't use the synthetic oils as the style of clutches that we run do not like it [not compatible].
- eddiem
- KZR FLAG RELAY CARRIER #63
- Thank you received: 34
21 Feb 2009 22:09 #266992
by eddiem
1976 Kz900
1978 Kz1000
1978 Z1r
1982 Kz1100 A2
1975 Z1b-900
1975 Z1b-900
Replied by eddiem on topic The best OIL to use!
how about this?
www.jksales.net/MotorcycleOil.htm
1976 Kz900
1978 Kz1000
1978 Z1r
1982 Kz1100 A2
1975 Z1b-900
1975 Z1b-900
- kano
- Not Another Bloody Limey!
21 Feb 2009 22:12 - 21 Feb 2009 22:15 #266994
by kano
Replied by kano on topic The best OIL to use!
ive used Silkolene Pro 4 Plus since 90 when i got the bike,have i been wrong all these years?
my motor is a gpz1100b1.
* The ultimate full synthetic ester 4 stroke high performance racing engine oil
* Utilizes Electrosyntec technology derived from aircraft turbojet engine lubrication
* Developed and tested with Factory race teams in Moto GP, Superbike, Supersport, Supermoto, Off-Road and Motocross competition
* High Viscosity Index, exceptional shear strength and outstanding thermal stability give excellent continous stay-in-grade performance
* Outstanding anti-wear, anti-friction and load-carrying properties
* Meets or exceeds API-SG, SH and SJ standards
* Motorcycle 4T JASO-MA2 certified
* SAE 10W-50
* SAE 10W-50
Last edit: 21 Feb 2009 22:15 by kano.
- Darkangel
21 Feb 2009 22:20 #266997
by Darkangel
Replied by Darkangel on topic The best OIL to use!
gtx is what the rest of my bikes use...I am a valvoline, and lucas, type guy...
- timebomb33
21 Feb 2009 22:27 - 21 Feb 2009 22:29 #267000
by timebomb33
i personally don't like to use synthetics because of 2 reasons one is as i mentioned the clutch issue i'm speacking from experiance with serious clutch creep and also the fact that synthetic flows a lot easier than conventioal oilswhen hot so if you have weak spot ina gasket or in a seal it will find it's way out very quickly and since we are dealing with 30 year old engines that have been apart and put back together un told times with scratched and gouged gasket surfaces and questionable seals why look for trouble it is my opinion that these new oils are very high quality but they belong in late model bikes that have seals designed for the qualitys of the current crop of oil's i appreciate that every bike owner want's the best for their bikes but i prefer to change the oil in my bike a little bit more often and spend my money on things that are important to the way the bike rides like in good quality tires the synthetics that you guy's have shown me are good oils without a doubt and have the proper api ratings that you need for bikes but i still wouldn't run them. but you know the old saying about opinions they are like assholes everybody has one so do what you think is best and what works for you.
Last edit: 21 Feb 2009 22:29 by timebomb33.
- trianglelaguna
- Thank you received: 235
21 Feb 2009 22:29 #267002
by trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
Replied by trianglelaguna on topic The best OIL to use!
some oil sales guys had a booth at the gp and were saying tis...and claiming that.....and finally i said hey what about motors that share their oil with the clutch plates....then the guy said quietly ....no this is not for that.....dont remember what co. or type of oil....tb is right ...allthough i just use any good 20-50 and change it a lot....am i wrong??????
1976 KZ900
2003 ZX12R
2007 FZ1000
- eddiem
21 Feb 2009 22:34 #267004
by eddiem
1976 Kz900
1978 Kz1000
1978 Z1r
1982 Kz1100 A2
1975 Z1b-900
1975 Z1b-900
changing oil on time seems to be the best way with any oil from what I've seen
1976 Kz900
1978 Kz1000
1978 Z1r
1982 Kz1100 A2
1975 Z1b-900
1975 Z1b-900
- timebomb33
21 Feb 2009 22:37 #267005
by timebomb33
i think the key here is to change it as needed if you notice the transmission or clutch is not operating as it should be change it if your running lots of miles in superhot weather change it more often if you are putting a lot of stop and go miles on it change if you ride very hard like i do change it more often use your best judgement give the motor what it wants i dont run synthetics in any of my engines and over the years i have had only one engine failure and that was due to breakage not to an oil issue. to each there own do what ever works for you i just believe strongly in motorcycle specific oils what ever the type.
- kano
21 Feb 2009 22:49 #267010
by kano
ok good info you said sg or sj rated oils
can you though some brands out there for the dumb English man lol.
we have a small napa here on the island and the max speed here is 45, gets hot as hell in the summer and cold as witches titty in the winter.
only reason i used this oil as i used to work in a bike shop and i got a good discount and went for the best or so i thought:blink: but that was in England 19 yrs ago.
- timebomb33
21 Feb 2009 22:53 #267013
by timebomb33
i should have phrased things a bit different if it works for you great i just have had some bad experiances with synthetics and am a firm believer in using it only in late model machines that have been designed with synthetics in mind.
