The best OIL to use!
  • Darkangel
  • Darkangel's Avatar Topic Author
Re: The best OIL to use!
21 Feb 2009 22:55
#267014
All I know is I love my bike...and whatever oil it needs...I will surely get her...My petcock was jacked up, and so the oil in my bike was no good...Plus it had been sitting for about 13 years...so yeah...it needed to go to say the least....But I will probably just go with GPX again for saftey, and some lucas oil additive..
_________________________________________
1983 Kawasaki KZ 1100 A2 - streetfighter
  • timebomb33
  • timebomb33's Avatar
21 Feb 2009 23:06
#267016
be carefull of putting extra additives in your oil as they are designed for an engine that does not share a clutch or transmission it can cause a lot of slippage in the clutch as the additves are usally friction modifiers designed to reduce friction in the engine which can make it to slippery for your clutch pack
I THINK MY POWERBAND BROKE
  • Darkangel
21 Feb 2009 23:07
#267018
this is true...
  • kpier998
  • kpier998's Avatar
21 Feb 2009 23:36
#267028
I run the Chevron Delo or Shell Rotella in my CB750. The KZ hasn't run in years, but when it does, I plan to use the same in it.
  • timebomb33
21 Feb 2009 23:47
#267033
ive heard thru the grape vine that alot of high dollar car engine builders are recommending for there clients to use desial oils in there engines for a couple of reasons one is the detergents that are in that type of oil and the second is they haven't changed the formulation like they have in car oils so it might work at least it will keep the engine clean i'd still be carefull with it if you do notice any wierdness happening with the clutch or the way it shifts switch back to motorcycle oils alot of the newer types of oils are so thin that they are being blamed for arash of flat tappet camshafts being wiped out in these crate motors that are now being built now adays also it is also giving some builders fits with hydraulic liftered motors and as our motors are basiclly flat tappet engines we could also have similar problems
  • Bluemeanie
  • Bluemeanie's Avatar
22 Feb 2009 06:03
#267054
eddiem wrote:
changing oil on time seems to be the best way with any oil from what I've seen
I've been using Valvoline 20-50 for many years with no problems. I agree that conventional motor oils are not designed for transmission applications but I change my oil every 1000 miles so no problem there. In 29 years my bike has never seen dirty oil.
  • Joe77A1
  • Joe77A1's Avatar
22 Feb 2009 06:22 - 22 Feb 2009 06:32
#267058
Thanks timebomb33 for your recommendation . I had the same oil-related question , as I've recently acquired a nice '77 KZ1000A1 and it will receive only the best possible treatment ! I've decided to use conventional Castrol 10W40 Grand prix 4 stroke motorcycle oil .
Last edit: 22 Feb 2009 06:32 by Joe77A1.
  • Jeff.Saunders
  • Jeff.Saunders's Avatar
  • Vendor
22 Feb 2009 06:46
#267064
The key is:
1) not to leave oil in the bike too long, 2) get the bike up to full operating temperature every time you take the bike out, and 3) avoid oils with friction reducing additives (stay with oils formulated for wet clutch operation).
Short trips cause condensation to build up inside the engine. This causes that milky white film you get on the inside of the oil window. You need to be running at least 25-30 miles when you take the bike out.
If you add an oil cooler, often they OVER cool the oil and this stops the condensation getting burned off (and stop component tollerances from coming up to spec).
Change your oil in the fall to clean out the old oil and all the contaminates that accumulate in it.
This email address is being protected from spambots. You need JavaScript enabled to view it.
www.z1enterprises.com
Z1 Ent on Facebook,
22 Feb 2009 06:50 - 22 Feb 2009 06:50
#267066
Here's what I found works best for me:
OIL
Last edit: 22 Feb 2009 06:50 by 650ed.
  • kztee
  • kztee's Avatar
  • TeeRoy
22 Feb 2009 07:26
#267073
"Change your oil in the fall to clean out the old oil and all the contaminates that accumulate in it."
THis makes sense. I usually change mine in the spring before taking her out for the first time. I will change up this practice.
1977 KZ 1000A - Currently rebuilding
1980 KZ 750 LTD - Mostly stock daily rider
1979 KZ 1000 LTD - Parts bike and/or future project
1979 KZ 1000 ST
1980 GS 750 L
2003 ZRX 1200 R
  • oldcoldankles
  • oldcoldankles's Avatar
22 Feb 2009 07:36
#267076
Good choice Joe, your motorcycle will love it as mine do and I have checked for wear metals per used oil analyses and they are very low. Welcome to the forum:)
Peachland BC
1981 KZ1000 CSR M1
1983 KZ550 LTD M1 (Shaft)
1989 Corvette coupe
  • PLUMMEN
  • PLUMMEN's Avatar
22 Feb 2009 08:25
#267092
the best oil to use is the kind you can get when you need it,absolutely useless if you cant get it in your area.:laugh:
