- Thank you received: 10
1100 sleeves in a kz block???
- timebomb33
I THINK MY POWERBAND BROKE
- jordan
- Thank you received: 5
KZ810 streetfighter kz/gpz/gsxr
1983 gs1100e
1979 KZ 1000 1428 dragbike project
1974 kawasaki H1 500 sold
1972 Kawasaki s2 350-parted on ebay
1973 Kawasaki s2 350-parted on ebay
1982 kz750(sold)
1978 kz650 hardtail(sold)
1975 honda xl250-sold
1971 yamaha R5-sold
1982 yamaha xs400
- timebomb33
- mark1122
- Keep twisting it
- Thank you received: 109
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- kaw-62046
- jordan
the gpz sleeves only bore to 1170cc and i dont think those gpz pistons would work in a kz . The gpz 1100 uses an 18mm pin. and the j pistons are taller i think.
They make an 1170 kit for j model pistons. I think i will go this route and end up using a j model head.
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
- mark1122
- Keep twisting it
Look here:
www.aperaceparts.com/tech/techkz1000.html
Get a price from APE on sleeving a block and 1200cc pistons.
Gast in NY charges $800 complete.
MRE charges $850 but will supply a block.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- kaw-62046
- PLUMMEN
- Thank you received: 104
83-84 1100 has 18mm pinsPistons... All pistons have 17 mm pin holes, but the J model/ '81-'82 GPZ1100 pistons have the pin hole lower in the piston to make up for the short connecting rod. All J model and early '81-'82 GPZ1100 pistons are the same ( '83-'84 GPZ has 18 mm pins ) Therefore any '81-'82 GPZ piston can be fitted to a J model engine to make a big bore engine. Pistons for the J model / '81-'82 GPZ1100 can not be used in a motor that has an early style long connecting rods ******unless a spacer plate is used under the cylinder block to compensate. *****If early style KZ pistons are used in an engine that has the short J model / '81-'82 GPZ1100 connecting rods, a special short cylinder block has to be used.
Look here:
- jordan
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
- kawsakiman
- Thank you received: 6
You can fit 1100 sleeves in the 750 block, let alone the 1000 :laugh:
I have a 73mm bore 904cc 750 turbo motor with 1100 sleeves and I know of another 904cc GPz750 (non turbo). The stock block does get pretty lightweight though..
all these new ideas are going to cost me a marriage someday.
- PLUMMEN
