- Thank you received: 235
can valves mimic elec trble??
- trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
- saxjonz
- KawboyZ
- Thank you received: 76
79 LTD B3
- saxjonz
- KawboyZ
After 30 years they can get corroded and make the path of resistance much higher causing many problems. If the box is bad I would replace it with the newer type fuse boxes and that will help out greatly with the heat issue. I hope you get it fixed. Can't wait to meet up in Cali this July to do some riding and watching the races. I got three guys with kaws possibly one more guy who is older who is on this site Cro Dog you should check out his ride. It looks better than new bikes look. The ignition switch if it is loose can make things go bad too. I remember my 69 mustang parking lights and dash lights never worked and had funny issues with the dome lights etc and when I changed out the ignition switch it all came back and worked like a charm. I hope you find it and don't go crazy doing so.
79 LTD B3
- l0g1c
- Hanging on for dear life.
- Thank you received: 1
Exactly what wireman said.
:ohmy: :ohmy: :whistle:
'81 KZ750 LTD
'72 CB350K
Omaha, NE
- PLUMMEN
- Thank you received: 104
3/8 turn out from seated?im no carbonator expert but ive always gone between 1 1/4- 1 1/2 as a starting point.my 76kz900 has a white wire ubder the right side cover that used to work half free and cuase stuttering and eventually the bike would die and not re-start... i fixed it a while back and know it is a suspect so i checked it again it is secure... i have a stuttering problem that i can rev down or up and get to clear out...allmost like i'm losing a cyl or two,,,on and off....I cleaned the 29's today , removed all the brass items in the bowls ,and they're still in good shape,cleaned reassembled,set mix screws at 3/8 turn out from lightly seated,,lubed the ignition advace, re-set the timing with a strobe timing gun,dyna s,checked the harness for the wiggly wire prob,re-charged my batterry -trickle- over night,new plugs & set gaps,and still my bike is coughing and stuttering ...but not popping or back firing thru the carbs...allthough it will hicup once in a while.....sunday i guess i'm gonna check valves????.. dyna failing?????...any ideas guys....thanks craig
- timebomb33
I THINK MY POWERBAND BROKE
- trianglelaguna
hey i missed that little bit of info that might be a place to look as well they should be around 1 1/2 turns out to start with
did not get over there today..went with some friends to that place on the wharf for fish and chips.. and walked downtown monterey,,,the presido,,,the piers after in a light rain...
but on the drive there and back...listening to Rick Dencko....i kept think about the wiring and what george and tmbmb33 said... and others....i think IT IS in the wires,battery conects,switchs,or in the hd-light somrwhere by the way it was cutting on to some cyl..but not shutting down ....thanks for all the feedback..........
i am gonna have a rain out for my pt sur tour tomorrow and am gonna find that problem....some times feedback and removing myself from the problem and walking thru it in my head a bit helps...thanks guys i'll post what happened tomorrow..peace craig
1976 KZ900
2003 ZX12R
2007 FZ1000
- trianglelaguna
i'm posting a pic(not my porsche carrera 4s allthough i wish it was).....
i alos am gonna post another reply with a part i.d
and a coil question...next entry....
1976 KZ900
2003 ZX12R
2007 FZ1000
- trianglelaguna
second question...
my green dyna coils were bought second hand/new in box...i got some auto wires and had to make em up then install em on the coils....my coils face up under the tank and the dyna wire weels face at an angle ,but,,,tight to the frames main center spine...the boots barely fiot in there and don't have a psoitive snap into the coils they just kinda suckerfish onto the coils and i was never happy with how tight it all is.....aside from running the coils on the frame above the exhuast does anyone know any wire manufactures or better any tricks to keep the coil end of the wire snugged into the coils...???thanks guys craig....
wish it did not gimme that little mini sputter makes me think the gremlin is still alive...we'll see
1976 KZ900
2003 ZX12R
2007 FZ1000
- trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
- Thank you received: 2098
The Dyna wires are inexpensive and available at Z1E in different colors. I'm very satisfied with the 7mm metal core plug wires. Here's a pic from Z1E.
The green Dyna coil primary terminal screw head is situated very close to the spacer on the coil attachment bolt. Sometimes it can short out against the spacer and prevent proper coil performance.
Plenty of different methods to insulate the screw head from the spacer. I use a couple of small nylon tie wraps pulled tightly next to each other around each spacer. The tie wraps can't go anywhere or fall out of place, and serve well in their role as little insulators.
Good Luck!
- trianglelaguna
I use Dyna plug wires which come with the cap grips aready in place and correct pinch clips for attaching before inserting into the coils. These clips fit nice and snug into the green Dyna coils.
Good Luck!
thanks patton i'm gonna switch to those wires and insulate my coil mount posts...that is another thing i noticed today and i tapped on a flat head screwdriver to re-space it a lttle.....my problem must be in that area ....thanks again....any one know what that unit in my previous picture is.....i think the p.o wired it in and i dont know what it is???????
1976 KZ900
2003 ZX12R
2007 FZ1000
