- Thank you received: 235
can valves mimic elec trble??
- trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
- trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- trianglelaguna
timebomb33 wrote:
what do you have for a fuel filter that igniton box your talking about is a dyna111 box it uses a different ignition plate than the dyna s the box that is on the bike already sounds like it might be a rev limiter does it say drl 200 on it anywhere.
1976 KZ900
2003 ZX12R
2007 FZ1000
- timebomb33
- trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
- timebomb33
- trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
- trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
- trippivot
- Thank you received: 3
it was where the wire contacted on the bakelight plate solder bubble and the brass spring loaded floating contact piece. the key twists and there are 2 of those spring contacts in there.
- trianglelaguna
trippivot wrote:
my 78 ltd had a loose connection issue under/inside the ignition switch. I put a new key switch on and problem went with old key switch. (K&L unit)
1976 KZ900
2003 ZX12R
2007 FZ1000
- wiredgeorge
I am not trying to say this will definitely fix your issues and lots of folks have chimed in with lots of very real reasons you could be having problems. I might not change ignition systems till I have tracked down what is causing the problem. The suggestion to check you main battery ground is also a good one. Easy to do and will cause this issue. The ignition switch suggestion is also a very real possibility.
