engine seized up help kz750
- mehall2
atlanta.craigslist.org/mcy/1035288145.html
'81 KZ550 LTD
'07 Yamaha FZ6
- jammor
1978 kz twin
- jammor
1978 kz twin
- jammor
jim
1978 kz twin
- gane
- Thank you received: 1
[img][/img] 1977 KZ1000A1
- jammor
thanks for the advice. i will completely tear the old engine down. I would like to see what seized, whcih journal, etc on the crank. Id like to compare that to my new bottom end (I bought a used 77 kz 750 engine today but judging by the condition of the top end-ruster- i am scared to death that this used engine bottom end is completly rusted- escept for the fact that then engine turns over.
so anyway---i have never disassembled one of these engines and taking apart my shot engine will be great experience. By chance I met another motorcylce mechanic tonight and he looked at the new (used0 engine and advised me not to take it apart but drain the oil, clean it as best i could, feel for play on the rods and just bolt my new top end on it.
I appreciate his advice but this engine has sat for !@ years and i see water in the crankcase. I want to make sure my engine is good from top to bottom so i will see how much effort it takes to disassemble the old engine and if not too much i would rather do what your are recommending (i think) and build it from the crank bearings up. I suppos the 78 has roller bearings and if it does i will not disassemble them. my bike has split bearings.
either way I think once i get into the crankcase i will feel more confident in either taking this task on or posting a great "prject bike" on kzrider.com!
1978 kz twin
- bountyhunter
- Thank you received: 337
Hi gane
I have the factory service manual. The bottom on the 750 twins is pretty complicated, due to the balancer assembly among other things. There are people here who probably could do it in their sleep, but you might want to get an FSM before you try it for the first time. It will alert you to the wierd stuff like having to install a 6mm screw somewhere to hold something in place and what not.
- jammor
1978 kz twin
