- Thank you received: 14
engine seized up help kz750
- Bluemeanie
- jammor
1978 kz twin
- OKC_Kent
- Thank you received: 20
Oklahoma City, OK
78 KZ650 B2 82,000+ miles
- jammor
1978 kz twin
- bountyhunter
- Thank you received: 337
And I failed to mention the original reason I rebuilt the top end was because the engine seized. Perhaps I simply have a bad oil pump- I think I really failed to consider what lower engine components could be bad...??
Sounds like the original problem is still there. was your engine oil light coming on before it siezed the first time?
- Thank you received: 2829
- jammor
nutshell: nothing I replaced failed!!! yeeehhaawww problem is in the crank that seized which was my initial problem to begin with but i missed it (and that sucks a big one).
I took the cams off- no scoring, burned marks, black marks, metal, etc---and lots of oil up there
still couldn't budge the engine with the cams off
pulled the head
no valve damage. the cylinders are on the bottom
pulled the cyls easy. They were not stuck and look just like when i got them back from the shop that honed them. No blown head gasket. No oil leaking outside the engine. No oil light ever went on (and it works cause i tested it).
Still cant budge the engine with the cyls off.
I think my problem was a bad journal on the crank. I had hoped refreshing the top end would fix my problem (initial engine seizure prior to the top end rebuild) and hoped the bottom end was good. Now I know it wasn't.
I do now appreciate using a micrometer as 650ed recommends for my peace of mind and perhaps the next time I put this together I will buy new parts---BUT i have a great top end here that didn't fail(thanks smith) and so I may use it again!!! If I do i will probably just pull it apart before I post too many questions:)
This has been a great learning experience for me and I appreciate all of your help.
So now I have a lead on an old kz 750 engine dirt cheap. If the crank turns I will buy it and put my top end on (with new rubber seals) and new other gaskets of course and see if it works. It is amazing how quicly I can tear this thing down now--- took 20 hours to assemble first time and 2 hours to take apart!!!
My mechanic says just try the old engine before I disassemble it and try to buy new crank bearings, etc. because they are expensive. he says i have probably damaged my current engine beyond repair. Says i can get the crank welded and resized but it never lasts---does that sound right to y'all
thanks
jim
1978 kz twin
- jammor
- jammor
- bountyhunter
Pretty much. Fixing the seized one would cost a lot. It's possible that a used one would have a usable bottom end: my 750 twin has about 80k miles and the bottom is still good (as far as I know). The bottoms on KZ's are supposed to be really strong.My mechanic says just try the old engine before I disassemble it and try to buy new crank bearings, etc. because they are expensive. he says i have probably damaged my current engine beyond repair. Says i can get the crank welded and resized but it never lasts---does that sound right to y'all
thanks
jim
I don't know if new bearings are available for the twins, Kawi doesn't stock many parts for them unless they are used in other models.
- SPARKY47
- 1980 KZ500 B2
- Thank you received: 5
If its 13034-044 you're referring to, they're $15 each.
1980 KZ500 B2
- BSKZ650
77 ltd1000, current rider
76 kz900, just waiting
