engine seized up help kz750
- jammor
then i heard a metal on metal sound- cam chain clatter???- and the engine froze- bike shut down.
I can shift through gears but the engine will not kick (I haven't tried turning it in reverse yet.....
So I guess I need to start tearing it donw to see what happened- anyone got suggestions of diagnostics I can perform before I pull the cylinders off?
thanks
Frustrated Jim
1978 kz750
1978 kz twin
- anarki650
- Thank you received: 5
If it won't turn over the first thing I'd think is seized pistons. Did you make sure the rings were positioned correctly when you installed the cylinders? I'd pull it apart and see what pieces are destroyed...that outta tell you what went wrong...
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
- bountyhunter
- Thank you received: 337
If it truly siezed upafter ten miles, I wonder if the pistons were not getting oil. Ten miles is about how long it takes the internals to get hot and expand into maximum size.
- flht1997
- Thank you received: 2
Matt Milwaukee, WI
75' KZ400, (5) 78' KZ400, 76' KZ 750, 78' KZ650
78'CB750F, 78' CB550K
89' BMW R100RT
05' H-D Electra Glide
06' KLR650
Do it right or don't bother doing it at all.
- franknsr
Formerly CSRchopper
1991 KZ1000P
Gone but not forgotten
1986 ZG1000
1982 650 CSR -shoulda kept this one-
Lisle Illinois, USA
- jammor
1. I have not removing the spark plugs and using a 17 mm yet but that is the first thing I will do. I was so pissed that I just parked the damn thing. I almost took a sledge to it but luckily i caught myself.
2. I put the proper amount of oil in it- does the engine oil lube the transmission or is that separate?
3. I was very careful to stagger the rings accarding to the book. Only thing is these are used rings and I did hone the pistons. The rings are only supposed to have about 900 miles on them. The end gap was about as thin as my thumbnail- my mechanic eyeballed the ring end gap but did not use a guage...
4. My starter clutch was bad when i bought the bike so i always have to kick it- of course I don't think i went anywhere near the starter clutch when working on the top end....
thanks for any ideas- ill post as i go if i tear it apart. I live in atlanta if you know anyone that wants to buy this bike..
1978 kz twin
- jammor
1978 kz twin
- bountyhunter
Oil flow going up top can easily be compromised if any junk falls down into the passages when the cylinder is being removed or replaced, or the base gasket is being scraped off. Also, you need new O rings on both sides to keep the pressure up top and prevent leaks. There are two O rings between the crankcase and cylinder, and four O rings on the two small steel tubes that join the cylinder to the head for oil flow.what could i have possibly done to restrict oil flow?
My wonder was if the used oil rings and the oil feed holes in the pistons were clear enough to get good oil flow to the cylinder walls.
- bountyhunter
It's all the same oil.2. I put the proper amount of oil in it- does the engine oil lube the transmission or is that separate?
jammor wrote:
Cold end gap is supposed to be about .010" - .012" (nominal) and about .025" (max) if I recall the spec.The end gap was about as thin as my thumbnail- my mechanic eyeballed the ring end gap but did not use a guage...
- jammor
I cant remember four O rings on the two small steel tubes that join the cylinder to the head for oil flow. I DO remember the large skinny O rings that went between cyl and crankcase. I remember two small O rings about the diameter of a pencil eraser- i think they went on top of the cylinders- this is a twin so wouldn't i just have two of them...?
anyway all the O rings were used....
1978 kz twin
- jammor
1978 kz twin
- jammor
thanks for any advice in advance
jim
1978 kz twin
