top head gasket leaking.
- SebRain77
- When in doubt, gas it!
Ever hit the pavement? I did, put that gear on!
1977 KZ 650C1 - First bike, ever! For sale - or not!?!?
2004 Z750 - More power than I'll ever need...
Gatineau, Qc, Canada eh!
- roy-b-boy-b
- Thank you received: 103
You will actually count to 28 a lot. Did i memtion there are 28 links between the timing marks?
And be very careful when you tighten the cam caps down. Take nore that there is a groove in the cam caps and you need to line the cams side to side so the caps don't bind and you break a cap. Roy
- Thank you received: 2829
- H2RICK
- Is this a fun bike, or what!!!
For some reason, you don't need any "non-permanent locking agent" on the cam cap bolts but you DO need it on the four bolts holding the upper chain guide sprocket. Must be because the guide sprocket bracket is kind of rubber mounted ???
KZ650C2 Stock/mint. Goes by "Ace".
H2A Built from a genuine basket case. Yes,it's a hot rod.
GT550A Stock/mint. Pleasant stroker.
2006 Bandit 1200S for easy LD rapid transit
Various H2 projects in the wings.
- MFolks
- Thank you received: 540
- kzmarvo
Watch it folks,i have sticky fingers when it comes to a nice looking set of handle bars:)
- bountyhunter
- Thank you received: 337
Did he quote you a price? That's all you really care about, not hours labor. I'd be surprised if a dealer would do it for less than $800, at least around here for sure.Man i'm gettin spooked. I have the clymer book,maybe i'll let the dealership handle it. The guy that is doing it is a straight guy that doesnt rip folks off,he is the one that told me right around 6 hours labor.
- RonKZ650
- Thank you received: 240
- keith1
do yourself and your wallet a favor...do it yourself..
if you are even semi mechanically inclined, do it yourself....i have the clymer manual and i read and re-read it 3 times b4 i jumped in....its basic nuts and bolts...i just completed my first top-end rebuild and with some help from the members here,
everything was good....it might seem like a duanting task, but it really isnt.....
- keith1
i would rate my skills as fair to middlin' and i can do the teardown in two hours...get a second set of semi mechanically inclined hands for assembly and thats 2 hours again....add an hour tops if alone....6 hrs is probably book and a good wrench can beat that all day....6 hrs at rate is a stealership bill....not to mention what they will bag you for cam chain componenets that depending
on mileage you will need...you can get em cheaper
than they will charge you....a stock head gasket is cheap....go with a cometic and fill the o ring groove...shave down chain rubbers flush and you,re good....advice that was given to me and it was good...
- kzmarvo
- keith1
I'm fairly mechanical,been working on cars since i was 13. I can do carbs,motor swaps,almost everything needed to keep something running. I just nenver got into taking a bike engine apart,never used a torque wrench,my ol man was oldschool like a mofo and would always tear it down and put it back the way it came apart and it always worked.
well, you are gonna need to know how to use a torque wrench.....20 bucks at harbor freight and i can tell you how to use it or about 50 other people here can....i used to twist many a wrench on old mopars twenty something years ago and this isnt any harder...trust me....keith
