- Thank you received: 1
Single pattern vs Dual pattern Cams
- gane
08 Feb 2009 16:18 #263032
by gane
[img][/img] 1977 KZ1000A1
Replied by gane on topic Single pattern vs Dual pattern Cams
Your' Right:blush: I'm sorry..Time for bottling, I'' be back G.
- PLUMMEN
- Thank you received: 104
08 Feb 2009 18:47 #263084
by PLUMMEN
Replied by PLUMMEN on topic Single pattern vs Dual pattern Cams
theres a little more then just a head and cam swap involved to get 130 hp out of one these engines . might i suggest very big pistons and some porting work a good set of carbs as a starting point!:laugh:
- joe k
08 Feb 2009 18:59 #263090
by joe k
Replied by joe k on topic Single pattern vs Dual pattern Cams
Was wandering if you were after info on the difference between symetrical and assymetrical cams as single pattern vs dual pattern it seems to be self explanatory although the only time a term like this would be used would be on single stick cams with dual profiles
- timebomb33
08 Feb 2009 19:28 #263106
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic Single pattern vs Dual pattern Cams
are you guys talking about cams that have a different profile for the intakes and the exhausts
- kzz1p
- One Test Is Worth A Thousand Expert Opinions!
- Thank you received: 3
08 Feb 2009 20:42 #263131
by kzz1p
Replied by kzz1p on topic Single pattern vs Dual pattern Cams
Once I had a 1013cc Z1 motor that needed some cams.
All I had was two mix-match cams laying around the garage. I had a time limit and needed something fast. This combination should of never worked, but it turned out to be one of my best set ups, ever.
.410" lift intake
.388" lift exhaust
300* intake duration
288* exhaust duration
109* intake L/C
116* exhaust L/C
112.5 LSA
29* overlap
In my book, this should not work at all. Well it ran good enough to beat a air shifted 1170(built by a local shop). The only new parts in that motor was the gasket set.
.410" lift intake
.388" lift exhaust
109* intake L/C
116* exhaust L/C
112.5 LSA
29* overlap
- timebomb33
08 Feb 2009 21:03 #263147
by timebomb33
i've been running a very mild old yosh intake cam and stock exhaust cam in my 1075 street motor for years and two years ago in sturgis it made 114 horse and 79ft of torque on the dragstrip dyno so i'd say they that kind of mismatchin cams works quite well. my big motor is going on the dyno next week or so and i'm running .460 intakes and .435 exhaust cams. grind 122/125 web cams i'm running them straight up at first for some bnaseline runs then i'm gonna degree them to web spec's and see what kind of numbers different there are. so i can let every body know.
