Single pattern vs Dual pattern Cams
  • kzz1p
  • Topic Author
  • One Test Is Worth A Thousand Expert Opinions!
01 Feb 2009 19:05 - 08 Feb 2009 01:11 #261617 by kzz1p
Well Guys lets move to something alittle different. Does anyone have any thoughts on Single pattern cams Vs. Daul pattern cams?:woohoo:
Last edit: 08 Feb 2009 01:11 by kzz1p.
07 Feb 2009 18:49 #262797 by KruZer
Replied by KruZer on topic Single pattern vs Dual pattern Cams
Ok I'll bite.
What are single and dual pattern cam? Intake and exhaut lobes different on the same cam?
Buzz
*1977 1000, 1975 KZ998 LSR bike.
07 Feb 2009 19:02 - 07 Feb 2009 19:05 #262799 by gane
Replied by gane on topic Single pattern vs Dual pattern Cams
OK, I'll be your' Huckleberry too. perhaps 4 valve as opposed to 2 (as in Suz. TSCC head?) or perhaps Honda's V-tec variable cam lobes, G
[img][/img] 1977 KZ1000A1
Last edit: 07 Feb 2009 19:05 by gane.
  • kzz1p
  • Topic Author
07 Feb 2009 22:53 - 08 Feb 2009 01:14 #262836 by kzz1p
Replied by kzz1p on topic Single pattern vs Dual pattern Cams
I had read on the net that VHR asked the NHRA for permission to use a 4 valve head. Back in the day when VHR was running the 2 valve Suz. Everyone went to the NHRA and perposed the 4 valve Suz. head. They said it would not produce any extra power.(HaHaHa) It said VHR perposed the 4 valve V-Rod head for approveal. It said that they got the okay. And the Suz. guys were crying. They wanted to know where they would get an extra 30-40 horsepower?
This is what I read, Take it for what it's worth........
Last edit: 08 Feb 2009 01:14 by kzz1p.
  • kzz1p
  • Topic Author
07 Feb 2009 23:27 #262838 by kzz1p
Single and Dual pattern cams can be used as a tuning tool.
Single pattern cams - both have the same lift and duration on the Intake & Exhaust cams. Generally speaking a single pattern cams produce more Torque. They are used when Intake flow is = to the Exhaust flow.
Dual pattern cams - have different lift and duration on the Intake & Exhaust cams. Dual pattern cams can be used in a couple of ways. Say you had a restricked intake system, with a good flowing exhaust system. You might want a cam with more intake lift or duration. If you had a motor with a good intake system and a restricked exhaust. You might give it more on the exhaust side. (Look at what the Z's are)
Then there are some guys that use bigger lift and duration on the intake side and smaller on the exhaust. They do this small on the exhaust because the exhaust valve is open when the piston is on it's way up. If use lose control of the exhaust valve, it hits the piston.
These cams can be used to produce high RPM horsepower.
08 Feb 2009 07:29 #262883 by otakar
Replied by otakar on topic Single pattern vs Dual pattern Cams
This is what I know. (Which is probably not much)On most of our vintage stock fours, the intake cam is timed differently than the exhaust cam. If you take a look at the Web-Cam sight for example, (I am talking about the WebCam with the Camsafts, and not the one with some little tart doing some funky dance in front of her computer)You will notice that all with the exception of the "Dwarf Car" cams are the same cams for intake and exhaust. This is because for more tork at lower end you want shorter exhaust duration. I also know that the Yoshimura "Bonneville" cams in my Z1-R are that way .385 intake and .360 exhaust. these cams are from 1978/79 I used to run consistent 10.87s and a top speed of 139mph after 1/2 mile. this was with some mild head work 29 smoothies and a RC1103 kit.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • trianglelaguna
08 Feb 2009 07:35 #262885 by trianglelaguna
Replied by trianglelaguna on topic Single pattern vs Dual pattern Cams
i googled "dual pattern cams" and got a site with mustang car guys talking about flow #'s and car stuff??????
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
08 Feb 2009 07:49 #262888 by otakar
I think when you are talking about this "dinosaur" technology in most of our US made V-8 with the single straddle cam, "Dual pattern" just makes it sound Hi-Tec. when you have DOHC and you can do individual adjustments and tweaking it just becomes "old hat" and you don't even think about the restrictions of a single cam buried somewhere in the bowels of your engine. I would like to have a race with some "Mustang jock" in doing cam swaps. I think I could swap out cams on all eight of my bikes in the time he could do it on his little mustang. :P
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
08 Feb 2009 15:28 #263011 by gane
I may be wrong, but I think I remember when the GS and KZ's were the Heavy Hitters in the 1/4 mile, 2 valvers were allowd a couple hundred extra cc's in class. If I could get the poke My gs1100/1164 has out of my KZ1000 just by swapping heads/cams/portwork, I'd be on it like stink on poo.G
08 Feb 2009 15:36 #263015 by otakar
You can, The best article I know of was in the 11/1978 "Cycle World" It was called "Taking it to the Tens" Today you can do much better. You can put a "J" or better yet a GPz head on the earlier engines and with a set of mild cams get 130 ponies.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
08 Feb 2009 15:48 #263022 by gane
Otakar, Thank-you. I had heard conversions were possible, But was under the impression that there were differences with cyl stud locations. a task I feel beyond me.perhaps mor3e research is in order. G
08 Feb 2009 15:58 - 08 Feb 2009 16:08 #263028 by otakar
NOPE, head will drop right on, You will just have to install an APE cam chain idler wheel in the head since the newer head uses a different chain guide system. This part is not much work at all here is a link that should help you. www.flowbenchtech.com/porting/CRH/kz-data.htm You can also look at my project on this sight.
kzrider.com/index.php?option=com_kunena&...w&catid=11&id=169462
I think that we hi-jacked this thread Wez-Bad:blush: we should shift this to a different thread
Otto
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 08 Feb 2009 16:08 by otakar.
