Top end question
- rdgrnr
when you scroll on the kz info at the top do you see anything in the filbase for your bike...just a thought
..lots of good stuff there, but no manual
77 KZ650B1
80 440 LTD Sold
78 GL1000 Naked Wing Sold
80 CM400E Sold
Brainerd, MN
- gane
- Thank you received: 1
[img][/img] 1977 KZ1000A1
- mark1122
- Keep twisting it
- Thank you received: 109
You could google the 650 forums and try them for a manual. Good luck.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- HerrDeacon
:blush: out now....head is off
..since I broke loose the jug/case gasket, it looks like the jugs need to come off as well...any advice before I proceed?
I'm thinking maybe slow down a bit til I get an OE manual..anyone have one on file?
Thanks everyone for the input:)
But were you able to separate the jugs from the head? Did you find the two small bolts inside the tunnel?
- Thank you received: 2098
old man rock posted a site with a lot of manuals. Try pm'ing him for the thread. i have it at home but my puter is down.
This may be the link mentioned by mark1122.
www.manualz.info/Manuals_pdf/
- rdgrnr
Yes, I found the 2 in the tunnel and separated the head/jugs.
I've been to the "manualz" link and the only thing for the 650 is the Haynes manual.
77 KZ650B1
80 440 LTD Sold
80 CM400E Sold
Brainerd, MN
- rdgrnr
Rgr, Can of worms. disturbed base gasket is probly consistantcy of stone. High miliage piston/rings sometimes lose seal after being dragged over unworn sleeves. and I'VE read std rings are nla. left to my own devices, I'd probly try brushing base gsk w.yamabond 4 and risk a new head gasket before disturbing rings. luck g
That isn't what I wanted to hear:unsure::laugh: Is it possible to just lube up the rings and slowly pull off the jugs?
I just think it would be a shame to be this far and not replace the base gasket. The #1 and #4 pistons are carboned up, and it seems like a good time to clean them as well.
....manual, oh manual, my kingdom for a manual:laugh:
...gonna keep looking for one...maybe ebay
77 KZ650B1
80 440 LTD Sold
80 CM400E Sold
Brainerd, MN
- bountyhunter
- Thank you received: 337
If it was mine I would pull the cylinder off and inspect/measure the wear. If the bike is relatively low mileage, like less than 40k miles, I would just give the cylinder a hone to break the glaze. If you can get a new set of rings at a decent price, go with them. If not, the old ones are probably servicable (inspect them).
If the cylinder bore or rings have rust, all bets are off.
YMMV
Definitely install a new base gasket and use 3-bond to seal it. My 750 came from the factory with gasket sealer on the base gasket. Clean the old one completely (that;'s a miserable job, but essential).
- rdgrnr
YMMV
Definitely install a new base gasket and use 3-bond to seal it. My 750 came from the factory with gasket sealer on the base gasket. Clean the old one completely (that;'s a miserable job, but essential).[/quote]
why clean the old one?
no rust noticed anywhere in the cylinders...mileage is under 30k...cylinders mic'd at 61.75 mm...it only really smoked at startup..thinking valve seals(have new ones).
My real concern, as I have never attempted this before, is fitting the jugs down over the pistons. Do I need a ring compressor for this, or will I be able to compress them by hand?
Thanks
77 KZ650B1
80 440 LTD Sold
80 CM400E Sold
Brainerd, MN
- bountyhunter
YMMV
[/quote]I meant clean away all the old base gasket residue. You need it to be clean to get a good install on the new gasket. The head torques staright down against the base gasket, you don't want anything funky there.
rdgrnr wrote:
You MUST use a set of ring compressors. You also have to get some props under the pistons. On the four hole engines, the pistons move as sets. Adjust them so one set is a bit higher than the other set and put the supports under them. Clamp the rings and slide the cylinder on just far enough to get the rings in. The lower set will still be free. Then transfer the ring compressors and supports and do the last two pistons.no rust noticed anywhere in the cylinders...mileage is under 30k...cylinders mic'd at 61.75 mm...it only really smoked at startup..thinking valve seals(have new ones).
Thanks
It's possible to level all four psitons and do them at once if you have enough ring compressors.
- gpzrox
Worst part of the job was cleaning the old gaskets off, took hours it seemed, but I did not want to mar the surfaces.
84 GPZ750. Modded with stock Kawasaki parts: ZR-7 shock, ZX-6 coils, GPZ1100 throttle, EN454 brake, GPZ900 fuse box, etc. and non stock: Ken Sears mirrors, K&N filter, Pirelli Sport Demons.
