Top end question
- rdgrnr
I am in the middle of taking the head off for a gasket replacement (in-frame), and I am wondering if anyone has a trick for separating the head from the jugs. It doesn't look like the heads/jugs will come off as a single unit while the engine is in-frame. The jug gasket is free, but the head doesn't want to come loose from the jugs...
Any suggestions?
77 KZ650B1
80 440 LTD Sold
78 GL1000 Naked Wing Sold
80 CM400E Sold
Brainerd, MN
- oldkaws4ever
- Have no regrets...... You only live once.
- Thank you received: 12
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- mark1122
- Keep twisting it
- Thank you received: 109
U can use the end of a short length of 2x4 wood, say about 6" long. place the wood on the head and hit upwards with a hammer on the wood.
Hope this helps.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- rdgrnr
tripple check to make sure u have ALL of the bolts out.
Hope this helps.
I did the tapping with a mallet, and the jugs came with the head. Anyone with a pic of the pry points. I already snapped a fin near the #4 intake:angry:
Also, anyone have a OEM manual? I have a Haynes, but it's not as comprehensive and the pics suck...
77 KZ650B1
80 440 LTD Sold
80 CM400E Sold
Brainerd, MN
- trianglelaguna
- Thank you received: 235
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
- HerrDeacon
- bountyhunter
- Thank you received: 337
Kawi hides small bolts in wierd places that help keep the head from seeping oil. Look and ye shall find.....limited exp here but are you sure you got all the bolts outta the head... 900s have two little 6mm bolts on the ends outside the outer sparkplugs as well as the heads stud "nuts"...bummer on the fin i feel your angst on that one.....good luck
- mariozappa
- Thank you received: 8
I just took mine off my 650 and there are two bolts in the timing chain tunnel. Did you get those. They are on either end of the tunnel (i.e. front and back).
That's what I was thinking.
1977 KZ650C1
and the KZ650/KZ750 Conversion
- rdgrnr
I just took mine off my 650 and there are two bolts in the timing chain tunnel. Did you get those. They are on either end of the tunnel (i.e. front and back). Let me know if you need a pic.
:blush: out now....head is off
..since I broke loose the jug/case gasket, it looks like the jugs need to come off as well...any advice before I proceed?
I'm thinking maybe slow down a bit til I get an OE manual..anyone have one on file?
Thanks everyone for the input:)
77 KZ650B1
80 440 LTD Sold
80 CM400E Sold
Brainerd, MN
- trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
- mark1122
- Keep twisting it
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- rdgrnr
what model ,cc" are u working on ?:side:
sorry, I forgot to mention that I am working on my 77 650B1
77 KZ650B1
80 440 LTD Sold
80 CM400E Sold
Brainerd, MN
