Top end question
19 Jan 2009 11:31 #258780 by rdgrnr
Top end question was created by rdgrnr
Ok,
I am in the middle of taking the head off for a gasket replacement (in-frame), and I am wondering if anyone has a trick for separating the head from the jugs. It doesn't look like the heads/jugs will come off as a single unit while the engine is in-frame. The jug gasket is free, but the head doesn't want to come loose from the jugs...
Any suggestions?
77 KZ650B1
80 440 LTD Sold
78 GL1000 Naked Wing Sold
80 CM400E Sold
Brainerd, MN
  • oldkaws4ever
  • Have no regrets...... You only live once.
19 Jan 2009 11:40 #258783 by oldkaws4ever
Replied by oldkaws4ever on topic Top end question
A few tap's from a rubber mallet around the edges should do the trick. There are also "Pry" points, to seperate the head and the fugs, but be careful when prying, hope this has helped.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
  • mark1122
  • Keep twisting it
19 Jan 2009 11:49 #258787 by mark1122
Replied by mark1122 on topic Top end question
tripple check to make sure u have ALL of the bolts out.
U can use the end of a short length of 2x4 wood, say about 6" long. place the wood on the head and hit upwards with a hammer on the wood.
Hope this helps.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
19 Jan 2009 12:08 #258791 by rdgrnr
Replied by rdgrnr on topic Top end question
Hope this helps.
I did the tapping with a mallet, and the jugs came with the head. Anyone with a pic of the pry points. I already snapped a fin near the #4 intake:angry:
Also, anyone have a OEM manual? I have a Haynes, but it's not as comprehensive and the pics suck...
77 KZ650B1
80 440 LTD Sold
80 CM400E Sold
Brainerd, MN
  • trianglelaguna
19 Jan 2009 12:26 #258797 by trianglelaguna
Replied by trianglelaguna on topic Top end question
limited exp here but are you sure you got all the bolts outta the head... 900s have two little 6mm bolts on the ends outside the outer sparkplugs as well as the heads stud "nuts"...bummer on the fin i feel your angst on that one.....good luck
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
19 Jan 2009 12:41 #258803 by HerrDeacon
Replied by HerrDeacon on topic Top end question
I just took mine off my 650 and there are two bolts in the timing chain tunnel. Did you get those. They are on either end of the tunnel (i.e. front and back). Let me know if you need a pic.
19 Jan 2009 12:50 #258807 by bountyhunter
Replied by bountyhunter on topic Top end question
Kawi hides small bolts in wierd places that help keep the head from seeping oil. Look and ye shall find.....
19 Jan 2009 13:03 #258810 by mariozappa
Replied by mariozappa on topic Top end question
That's what I was thinking.
1977 KZ650C1
and the KZ650/KZ750 Conversion ;)
19 Jan 2009 13:26 #258813 by rdgrnr
:blush: out now....head is off
..since I broke loose the jug/case gasket, it looks like the jugs need to come off as well...any advice before I proceed?
I'm thinking maybe slow down a bit til I get an OE manual..anyone have one on file?
Thanks everyone for the input:)
77 KZ650B1
80 440 LTD Sold
80 CM400E Sold
Brainerd, MN
  • trianglelaguna
19 Jan 2009 13:43 #258817 by trianglelaguna
when you scroll on the kz info at the top do you see anything in the filbase for your bike...just a thought
1976 KZ900
2003 ZX12R
2007 FZ1000
  • mark1122
  • Keep twisting it
19 Jan 2009 13:56 #258819 by mark1122
what model ,cc" are u working on ?:side:
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
19 Jan 2009 14:04 #258824 by rdgrnr
sorry, I forgot to mention that I am working on my 77 650B1
77 KZ650B1
80 440 LTD Sold
80 CM400E Sold
Brainerd, MN
