kz1000 mkII oil cooler plumbing.
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- Thank you received: 2098
Yes you do have to bend them. A tubing bender is cheap. and you can get the lines at any appliance store or hardware store. I bought mine at McMaster-Carr along with all the required plumbing. The thing I did not like about reinforced rubber hoses was that they were so Hulking Fat and Gaudy.
Am intrigued with idea of the much smaller shaped aluminum tube oil cooler lines instead of the fat ugly rubber hose, and hope a picture may be forthcoming. Had considered stainless steel braid covering to "beautify" the black rubber hose, but decided against the steel braid, being fearful it would chafe against whatever it contacted (frame, wiring loom, painted parts, etc.) running from the front cooler along the upper frame to behind the carbs, and actually draw more attention to the hoses (which I preferred keeping less noticeable). Thinking the softer ugly rubber hose minimizes the abrasive contact with whatever it touches, and that the matte black rubber hose sort of disappears in the mix. Yes, it's still ugly, and imo so is the obnoxious looking hunky oil cooler.
Am concerned that the gas-flex, plastic covered version, seems about the same O.D. as the rubber hose. And while the gas-flex may last forever, the rubber hose is relatively inexpensive and lasts a very long time.
Just devil's advocate thoughts regarding the gas-flex, with no denigration intended.
Good Luck!
- Tony
- Thank you received: 13
As soon as I pull out the bike from storage in the spring i will post some pictures.
That would be great. Thanks.
- keith1
cosmetically appealing.....dying to see pics....
- stephenzone
71-H1 Cafe w/750 engine
73-Z1 wifey's 1105cc
74-Z1 RatRod 1393cc
- Captaingamez
1979 Kz1000 MKII road racer project
1994 Seca II, pile in the corner
1973 Honda cb175 cafe racer
1971 Yamaha AT1
1975 Massey Fergusson MF440
1971 Skiroule 300rr
- Captaingamez
1971 Yamaha AT1
1971 Skiroule 300rr
- keith1
- keith1
- keith1
- PLUMMEN
- Thank you received: 104
- Captaingamez
1971 Yamaha AT1
1971 Skiroule 300rr
