kz1000 mkII oil cooler plumbing.
  • Captaingamez
  • Topic Author
18 Jan 2009 08:37 #258573 by Captaingamez
kz1000 mkII oil cooler plumbing. was created by Captaingamez
hey guys im plumbing an oil cooler to go on my kz1000 j i have a Derale cooler, a lockhart oil thermostat. and i grabbed some fittings from the junkyard. i got some old Earls braided line with hose ends also. but it leaked a bit so i have to replace it. serves me right for deciding to try hose from a junkyard but oh well. wondering what i should replace it with. what differance will it make on cooling if i got with stainless steel, nylon braided, or regular old rubber? i was also considering (just for coolness factor) converting it to AN fittings. any ideas?
1979 Kz1000 MKII road racer project
1994 Seca II, pile in the corner
1973 Honda cb175 cafe racer
1971 Yamaha AT1
1975 Massey Fergusson MF440
1971 Skiroule 300rr
18 Jan 2009 08:58 #258577 by otakar
Replied by otakar on topic kz1000 mkII oil cooler plumbing.
I run solid Aluminum lines to mine. This actually helps the cooling quite a bit, because the surface of the Aluminum lines is quite large, and Aluminum dissipates heat extremely well.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • Captaingamez
  • Topic Author
18 Jan 2009 09:00 #258578 by Captaingamez
Replied by Captaingamez on topic kz1000 mkII oil cooler plumbing.
aluminium lines? do you have to bend them to fit?
1971 Yamaha AT1
1971 Skiroule 300rr
18 Jan 2009 09:14 #258583 by otakar
Yes you do have to bend them. a tubing bender is cheep. and you can get the lines at any appliance store or hardware store. I bought mine at McMaster-Carr allong with all the required plumbing. The thing I did not like about reinforced rubber hoses was that they were so Huking Fat and Gaudy.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
18 Jan 2009 10:05 #258585 by Tony
Replied by Tony on topic kz1000 mkII oil cooler plumbing.
Do you have a picture of you installation and if so, would you be able to post it. Thanks. :)
  • Captaingamez
  • Topic Author
18 Jan 2009 11:34 #258596 by Captaingamez
i love the idea of the aluminium lines thats pretty sweet. but for this project i have a bunch of stuff to go with the hoses already. i just dont know what i should get and which has an advantage over the other.
1971 Yamaha AT1
1971 Skiroule 300rr
18 Jan 2009 13:03 #258603 by otakar
The nice part about hoses is that it is simple. Aluminum with Flair fittings is not much harder though. As soon as I pull out the bike from storage in the spring i will post some pictures.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
18 Jan 2009 13:08 #258604 by MFolks
Replied by MFolks on topic kz1000 mkII oil cooler plumbing.
The website www.earlsserviceshop.com sells oil coolers,lines and fittings that probably will work.
18 Jan 2009 13:48 #258613 by otakar
I just took a look at that web sight. Boy, one thing I never thought of was using Gas-Flex hose to hook up an oil cooler. By the time the oil gets into the cooler, the cooler is no longer needed. plus bending the line is no problem. The only thing remaining to solve is attaching a fitting at one end. Modern Gas-flex is Stainless steel and would last forever.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
18 Jan 2009 14:02 - 18 Jan 2009 14:03 #258616 by otakar
Just looked it up and found out that all gas flex lines come with a choice of 3/8 or half inch stainless connectors and come in lengths starting at 12" and in increments of 6". The hoses are available in 3/8 OD and 1/2 OD. Coming Spring I am changing over to Gas-Flex lines. MFolks, thanx for the revelation.:silly: :cheer:
www.plumbingstore.com/gasconnectors.html
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 18 Jan 2009 14:03 by otakar.
18 Jan 2009 14:10 #258618 by otakar
I did forget to mention something about Gas-flex, that is if it is a bit too short, it can be stretched out quite a bit.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
18 Jan 2009 14:15 #258621 by stephenzone
Replied by stephenzone on topic kz1000 mkII oil cooler plumbing.
are you running them over top? around the block?
71-H1 Cafe w/750 engine
73-Z1 wifey's 1105cc
74-Z1 RatRod 1393cc
