kz1000 mkII oil cooler plumbing.
- Captaingamez
1979 Kz1000 MKII road racer project
1994 Seca II, pile in the corner
1973 Honda cb175 cafe racer
1971 Yamaha AT1
1975 Massey Fergusson MF440
1971 Skiroule 300rr
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- Captaingamez
1971 Yamaha AT1
1971 Skiroule 300rr
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Tony
- Thank you received: 13
I run solid Aluminum lines to mine. This actually helps the cooling quite a bit, because the surface of the Aluminum lines is quite large, and Aluminum dissipates heat extremely well.
Do you have a picture of you installation and if so, would you be able to post it. Thanks.
- Captaingamez
1971 Yamaha AT1
1971 Skiroule 300rr
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- MFolks
- Thank you received: 540
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
www.plumbingstore.com/gasconnectors.html
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- stephenzone
71-H1 Cafe w/750 engine
73-Z1 wifey's 1105cc
74-Z1 RatRod 1393cc
