GPZ550 - KZ550C oil pan and cooler compatability
- Kirkpatrick
Re: GPZ550 - KZ550C oil pan and cooler compatability
19 Sep 2016 16:38
I think I figured it out. Both connect the front right section of the oil pan the the "out" to cooler on the bottom port and the return on the top port.
1983 Kawasaki KZ550
1983 Suzuki GS1100ED
1982 Suzuki SZ1000 (Katana)
1997 Honda CR500
1997 Honda CR500
- loudhvx
19 Sep 2016 22:41 - 19 Sep 2016 22:52
I pm'd you. As Martin said, you were comparing base numbers that only designate what the object is. 49034 just means oil pan, in general. Your bike specifically uses 49034-1002 as the oil pan. The gpz pan is 49034-1081. I'm not sure if it will bolt on to your motor. To get an idea, you should check the full part number for both oil-pan gaskets in question.
Check the 1982-1983 Kz550H1/H2 and 1984-1985 Zx550A1/A2. There is also a chance the 1981 Kz550D1 pan might fit. Those are all of the Gpz550's released in the U.S. I'm not sure if the Zx600 (liquid cooled Ninjas) might use the same pan or not, but you could check them too.
Looks like Corey, above, looked up the gasket numbers already. So it would be a matter of trying it. I thought I recall something about oil-pan gaskets in some gasket kits looking different, but I don't remember why, or what the difference was.
The oil pans have a flat machined area in the front with holes for the cooler hose, and the mounting flanges. I suppose if you changed the hose connections on the cooler, you might be able to drill and tap a standard oil pan, but you'd be breaking new ground on the 550's, as I've never seen it done. Everyone usually just finds a trashed gpz motor and snags the pan and cooler.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Last edit: 19 Sep 2016 22:52 by loudhvx.
The following user(s) said Thank You: Kirkpatrick
- loudhvx
19 Sep 2016 22:57 - 19 Sep 2016 22:59
By the way... is your bike having heat-related issues? If it's totally stock, it shouldn't be having too much trouble unless you live in Vegas or Tucson or something... ooh, I see you're in CA. I suppose it can get a little warm there.
1981 KZ550 D1 gpz.
Other links.
Other links.
Last edit: 19 Sep 2016 22:59 by loudhvx.
20 Sep 2016 05:36
I added an oil cooler to my KZ750E by installing the later model oil pan and a cooler/lines off a GPz. Just the same as you are attempting. It was a straight bolt on other than I had to fab up some mounts where the cooler bolted to the frame. Overall, it's a very clean installation. Just about every Japanese air cooled bike sold after the mid 1980's came from the factory with an oil cooler so I think it's an intelligent mod.
- Kirkpatrick
20 Sep 2016 13:59 - 20 Sep 2016 14:05Just want all the protection during the hot months. Also, Should I be running a 10w or 20w oil?loudhvx wrote: By the way... is your bike having heat-related issues? If it's totally stock, it shouldn't be having too much trouble unless you live in Vegas or Tucson or something... ooh, I see you're in CA. I suppose it can get a little warm there.
1983 Kawasaki KZ550
1997 Honda CR500
1997 Honda CR500
Last edit: 20 Sep 2016 14:05 by Kirkpatrick.
- Kirkpatrick
20 Sep 2016 14:05 - 20 Sep 2016 14:18
Is that an oil pressure sensor coming out of the bottom? If so, was it cut or does it tie into something? Never mind, found it. They just cut it off pretty short.
Kirkpatrick wrote: I found this on ebay and trying to figure out where the oil lines go.
1983 Kawasaki KZ550
1997 Honda CR500
1997 Honda CR500
Last edit: 20 Sep 2016 14:18 by Kirkpatrick.
The following user(s) said Thank You: meyrick
- Kirkpatrick
20 Sep 2016 20:10
Is the oil pan pressurized throughout the pan so that I can drill and tap a pressure gauge? or is it only in the oil cooler "out" line (on the oil cooler)?
1983 Kawasaki KZ550
1997 Honda CR500
1997 Honda CR500
- loudhvx
21 Sep 2016 07:23
The oil coolers came out as a result of upping the performance, like increased compression and longer valve duration on the gpz. The standard motor should be fine without it (as they've been around over 35 years without it already), but it certainly is not a bad idea in hot climates.
As for the oil, I've only tried 20W50 once, and that was only because the motor was really worn and starting to make noise. It didn't help the problem, and it really made the engine sluggish compared to 10w40. But I only deal with 90 to 100 degree temperatures a few weeks out of the year, and spend a lot more time dealing with cool temps where I actually block the oil cooler with a piece of sheet metal.
1981 KZ550 D1 gpz.
Other links.
Other links.
- loudhvx
21 Sep 2016 07:29That I'm not sure. Maybe there is something on it in the manual, like a oiling diagram. But if you want an oil pressure gauge, I think you could just use the pressure switch tap on your oil pan, or the 1981 gpz oil pan (if it fits, as it's the older styled motor). Unfortunately the newer styled gpz motors (82-85), use an oil level indicator. I'm not sure if they retained the tap for an oil pressure switch, but if they did, you could attach your gauge there.Kirkpatrick wrote: Is the oil pan pressurized throughout the pan so that I can drill and tap a pressure gauge? or is it only in the oil cooler "out" line (on the oil cooler)?
1981 KZ550 D1 gpz.
Other links.
Other links.
