GPZ550 - KZ550C oil pan and cooler compatability
  • snorules
  • snorules's Avatar Topic Author
12 Jan 2009 21:52
#257601
I was thinking of adding an oil cooler to my 1980 KZ550C. Is it just as simple as swapping to a GPZ oil pan and cooler? I don't mind fabbing brackets to mount the cooler, so if the pan fit, seems like an easy upgrade. Anyone done this? pros, cons, etc?
Sarge
1980 KZ550C (daily rider)
1981 KZ1000J (bagger project in progress)
1981 GS1100 (future dragbike)
1978 Z1R (not mine yet, but trying to work out a deal to acquire it).
  • loudhvx
  • loudhvx's Avatar
Re: GPZ550 - KZ550C oil pan and cooler compatability
12 Jan 2009 23:35
#257610
I haven't done it, but should not be a problem. The 81 kz550D GPZ motor uses the same bottom end castings as the 550C so it should bolt on. I can't say for sure if the 82-83 KZ550H gpz oil pans will bolt on or not.
  • CoreyClough
  • CoreyClough's Avatar
  • GPz550 Addiction
16 Jan 2009 08:25
#258223
The 550 oil pan gasket fits the following models:
KZ550-A1 (1980)
KZ550-A2 (1981)
KZ550-A3 (1982)
KZ550-A4 (1983)
KZ550-C1 (LTD) (1980)
KZ550-C2 (LTD) (1981)
KZ550-C3 (LTD) (1982)
KZ550-C4 (LTD) (1983)
KZ550-D1 (GPz) (1981)
KZ550-F1 (Spectre) (1983)
KZ550-F2 (LTD Shaft) (1984)
KZ550-H1 (GPz) (1982)
KZ550-H2 (GPz) (1983)
KZ550-M1 (LTD Shaft) (1983)
KZ750-G1 (LTD II) (1980)
ZR550-B1 (Zephyr) (1990)
ZR550-B2 (Zephyr) (1991)
ZR550-B3 (Zephyr) (1992)
ZR550-B4 (Zephyr) (1993)
ZX550-A1 (GPz) (1984)
ZX550-A2 (GPz) (1985)
ZX550-A3 (GPz) (1986)
The '82-'86 GPz550 had an oil level sensor in it, where your's has an oil pressure sensor I believe?
I'm thinking you shouldn't have any issues with bolting one right on if the gaskets are the same, oil cooler and all. You'd just need to make some fittings to mount the cooler to the frame.
The GPz550 Pan:
Your oil pan was used on the following:
Model (8):
KZ550-A1 (1980)
KZ550-A2 (1981)
KZ550-A3 (1982)
KZ550-A4 (1983)
The '81 GPz550-D1 had the oil pressure switch in the pan and is a one year, one model only part, according to www.buykawasaki.com Looks the same, but might be different side pressure switch or something to have a different part number for the pan and switch.
'85 GPz550(ZX550-A2)
  • steell
  • steell's Avatar
16 Jan 2009 08:59 - 16 Jan 2009 09:04
#258226
I just checked and it actually does say "KZ750-G1 (LTD II) (1980)", but I don't believe it. I think it's another parts diagrams screw up :)
I looked up the oil pan gasket for a 1980 KZ750G, and it fits the following.
KZ750-B1 (1976)
KZ750-B2 (1977)
KZ750-B3 (1978)
KZ750-B4 (1979)
KZ750-K1 (LTD Belt) (1983)
KZ750-K2 (Canada Only) (1984)
KZ750-M1 (CSR Twin) (1982)
That makes sense, same gasket fitting a 550 is crazy :D
Last edit: 16 Jan 2009 09:04 by steell.
  • snorules
16 Jan 2009 11:43
#258257
I was thinking about drilling and tapping my stock oil pan (I have an extra just in case) for some fittings, using a generic oil or trans cooler from a car, and using copper tubing to plumb it all in. More work than switching pans, but cheaper and I think it will look cool as hell.
Sarge
  • CoreyClough
  • GPz550 Addiction
16 Jan 2009 12:11
#258262
Oil cooler and lines on ebay:
tinyurl.com/8flkv9
That's half the battle.
  • Kirkpatrick
  • Kirkpatrick's Avatar
19 Sep 2016 14:19
#742906
Ok, time to resurrect the threat. All of the gaskets listed are part # 11009. The problem i am running into is that on PartZilla, all of the Oil pans for the different model and year 550's are listed as 49034. I have been PM "LoudHVX" but don't want to keep beating up his inbox.
83 Kz550a4 www.partzilla.com/parts/search/Kawasaki/...+A3-A4%29/parts.html
84 GPZ 550 www.partzilla.com/parts/search/Kawasaki/...50-A1+GPz/parts.html
The only difference is that there is an oil cooler option for all of the GPZ's in the main menu.
1983 Kawasaki KZ550
1983 Suzuki GS1100ED
1982 Suzuki SZ1000 (Katana)
1997 Honda CR500
  • martin_csr
  • martin_csr's Avatar
19 Sep 2016 15:05 - 20 Sep 2016 04:47
#742910
11009 is the diagram reference number & not the full part number. same goes for 49034.
click the part to get the part number & cross-reference. the x-ref isn't 100% accurate, so double check the results with the donor models or at Kawasaki.com if possible --- their info is incomplete since they changed their site several years ago.
If you have a 550A & the gasket is the same as the GPz or Zephyr 550, then I'd guess you could use the oil pan from one of those models. KZ/ZX/ZR/550. The 550H & ZX have a large oil level sensor in the oil pan.
Last edit: 20 Sep 2016 04:47 by martin_csr.
  • Kirkpatrick
19 Sep 2016 15:25
#742914
No eBay APP ID and/or Cert ID defined in Kunena configurationI found this on ebay and trying to figure out where the oil lines go.
1983 Kawasaki KZ550
1997 Honda CR500
  • martin_csr
19 Sep 2016 15:38 - 19 Sep 2016 15:42
#742918
Don't quote me on this, but I think both oil lines connect to the flange on the front/leading edge of the oil pan. If you do a search for ZR550 oil pan, you can get a better look at the flange & how the oil would flow thru the pan.
If the 550 manual has an oil flow see-thru engine diagram, you might be able to figure out how the oil flows.
Last edit: 19 Sep 2016 15:42 by martin_csr.
  • Nessism
  • Nessism's Avatar
19 Sep 2016 15:39
#742919
Kirkpatrick wrote: I found this on ebay and trying to figure out where the oil lines go.
One is a feed and the other a return. You should be able to purchase a 550 cooler w/lines for cheap too, that way you then get a complete kit.
  • Kirkpatrick
19 Sep 2016 15:57 - 19 Sep 2016 16:03
#742923
I have searched for the better part of the day and get lots of pics but none that specifically show where they connect. Another member talked about drilling and tapping the pan but I assume there has to be some sort of push/pull to the oil of which one of the line is pressurized and one is a return.
I assume by the attached image that the lines connect directly to the front. Does none connect to the pump section of the pan?
1983 Kawasaki KZ550
1997 Honda CR500
Last edit: 19 Sep 2016 16:03 by Kirkpatrick.
