- Thank you received: 225
motor extraction/insertion
- Old Man Rock
14 Jan 2009 04:03 - 14 Jan 2009 04:07 #257813
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic motor extraction/insertion
The easiest method I found (one person job) is with the bike stripped to the frame minus the motor... Front end off and at least rear tire off.
Frame on ground/boards, bolts loose.
Tape of frame where motor may chip/scratch during removal.
Towel laid out on floor, right side of bike.
Remove bolts and motor mounts.
Remove top end valve cover, cams & head.
Standing over bike straddled.
Slightly lift & remove engine out of right side.
Now lift and carry onto work table/bench.
Installation is the reversed.
One Man Job...
OMR
One Man Job...
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 14 Jan 2009 04:07 by Old Man Rock.
- Old Man Rock
14 Jan 2009 04:08 #257815
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
