- Thank you received: 1
motor extraction/insertion
- gane
[img][/img] 1977 KZ1000A1
- trianglelaguna
- Thank you received: 235
hey i saw your answer about taking the motor out yourself... i took a z-1 out a few weeks back and i left the kickstarter on and my girl with a glove on her hand helped pull up on the kickstarter as i did the lifting out in small stages ...we got it balanced on the frames left cradle and i came around the bike and she was all into helping ..she really just steered the wheight from the kickstarter as i lifted it to a stand on the ground...i know you know all this...i just thought it was really easy for her and she said it was'nt even heavy...i was gonna do it myself too..so as not to yell at her if it started tipping and start a fight...but together it was a breeze...the third hand helped tons ....good luck
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
- Mark Wing
- Thank you received: 22
Yorba Linda Cal.
- oldkaws4ever
- Have no regrets...... You only live once.
- Thank you received: 12
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- gane
- PLUMMEN
- Thank you received: 104
yepCan i leave the jugs off of my z1 900 when i put the motor back in? Can i fit the jugs on while the motor is in the frame?
- arai59
- Banned
- oldkaws4ever
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- mark1122
- Keep twisting it
- Thank you received: 109
I lift the motor out with a helper and rest(balance) it onto the right side lower rail. Then walk around to that side so both of us can finish the removal from the rt side.
I tried pluming pipe foam once but the motor cut throgh it and chipped my new paint.With powder coat u may get away with less than the 1/16" thick ruber i used.
I took mine out again yesterday. since i am taking it apart anyways i removed the head, cyl,and pistons first.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- toates89
- stephenzone
pict of engine on table after removal with chain dolly
71-H1 Cafe w/750 engine
73-Z1 wifey's 1105cc
74-Z1 RatRod 1393cc
- mark1122
- Keep twisting it
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
