motor extraction/insertion
11 Jan 2009 20:02 #257375 by dman3998
motor extraction/insertion was created by dman3998
I know this may sound like a really dumb question but I had a heck of a time getting the motor out of the frame when I started my rebuild project. (1000 B3) I even took off the PCV outlets on the top and the oil filter cover on the bottom.
How does one get it back in without scraping the hell out of the frame? or the motor for that matter. and yes I took off all the removable mounts and brackets. I did it alone that probably didn't help. must be some tricks to it.
Thanks\
dman
Dman
SE Idaho
"Smart only goes just so far, STUPID is UN-limited"
79 KZ1000 LTD
Honda XRL650L
Yamaha RD350B
Yamaha DT400B
11 Jan 2009 20:07 #257380 by timebomb33
Replied by timebomb33 on topic motor extraction/insertion
i take old inner tubes and slice them lentgh ways then wrap them around the frame tubes stand over the frame and lift away the rubber will keep the frame from getting chewed up on some frames it is easier to pull the valve cover and install it that way. i've heard of guys laying the frame over the engine on its side but i've never tried it my self.
I THINK MY POWERBAND BROKE
  • oldkaws4ever
  • Have no regrets...... You only live once.
11 Jan 2009 20:18 #257396 by oldkaws4ever
Replied by oldkaws4ever on topic motor extraction/insertion
On my kz650 project, i layed the motoron the side and slid the frame over it, that worked out quite wel with only minor scrape. im intrested to hear the responses because im gonna pull the motor on my z1 for a rebuild, and dont wanna scrape the frame when it goes back together.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
  • Kawickrice
11 Jan 2009 20:18 #257397 by Kawickrice
Replied by Kawickrice on topic motor extraction/insertion
I do it like timebomb, except didn't use tubes and scratched the frame. Sit on the bike normally and lean over and heave a little here and shake a little there. B)
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
11 Jan 2009 20:20 - 11 Jan 2009 20:21 #257399 by snorules
Replied by snorules on topic motor extraction/insertion
I've done the "lay the bike on it's side and lift the frame from around the engine" thing. It works, but it's still a pain. Now if I'm gonna pull an engine, I take off as many parts as possible to make it lighter and more manageable first. Covers, clutch, starter, valve cover, cams, head, drain the oil. I may seem like a pain, but I find it easier and faster, not to mention easier on the back..the things are heavy!
Sarge
P.S. It also helps to have at least 2 people to help you pull it out.
1980 KZ550C (daily rider)
1981 KZ1000J (bagger project in progress)
1981 GS1100 (future dragbike)
1978 Z1R (not mine yet, but trying to work out a deal to acquire it).
Last edit: 11 Jan 2009 20:21 by snorules. Reason: forgot something
11 Jan 2009 20:24 - 11 Jan 2009 20:25 #257401 by dman3998
Replied by dman3998 on topic motor extraction/insertion
I laid it on its side to get it out. but after spending a million hours shining up covers and painting the frame I kinda wanted to avoid any damages. Maybe I can make a wood and carpet blocking set up that would hold the motor on its side without scratching anything and then drop the frame over it. have to noodle on it for a while.
thanks for the suggestions.
dman
Dman
SE Idaho
79 KZ1000 LTD
Honda XRL650L
Yamaha RD350B
Yamaha DT400B
Last edit: 11 Jan 2009 20:25 by dman3998.
11 Jan 2009 20:27 #257403 by timebomb33
i've tried to use help when i put engines in or take them out but i always seem to get my fingers crushed when i get help so i just do it my self. by the way i've never weighed one of those engines any idea how much they weigh.
  • oldkaws4ever
11 Jan 2009 20:33 #257408 by oldkaws4ever
ya i know what ya meen timebomb, everytime i have a friend help i smash multiple fingers, and usually end up throwing wrenches through the garage wall and drinking lots of beers afterwards...........im not sure on the weight of them. Probally around 200 or so?
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
11 Jan 2009 20:42 #257411 by snorules
I'm guessing they weigh 160-180 at least. all I know is they are a s@#tload lighter with all of the parts off of them. I pulled my 550 motor the other day, that thing was a feather compared to my J motor.
Sarge
  • Kawickrice
11 Jan 2009 20:48 #257412 by Kawickrice
I don't know if its the weight, or just the awkwardness of straddling, and bending, but it sure gives the lower back a workout. It ain't fun till she runs, then you seem to forget about the pain.:laugh:
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
11 Jan 2009 21:02 #257415 by dman3998
I just found a post on wiredgeorges forum about installation. The guy uses some 1x3 boards to straddle the frame, slides the motor in then jacks it into place with a floor jack. has potential.
Dman
SE Idaho
79 KZ1000 LTD
Honda XRL650L
Yamaha RD350B
Yamaha DT400B
11 Jan 2009 21:14 #257418 by PLUMMEN
Replied by PLUMMEN on topic motor extraction/insertion
put a floor jack under it if the rest of the bike is together to help start removal process.wrap the frame with some water pipe insulation like you buy at menards when you put it back in,and remove exhuast studs before you remove it or install it every inch helps!B)
