- Thank you received: 76
Just got my kz 1000 head and have ?'s already
- saxjonz
- KawboyZ
I know parts are costly and having someone else do it for you may not be in your budget but maybe you should just hold off on that rebuild until you get the funds to do it right. That bike could be worth really serious money if done right or you could make it worth less by not doing it proper.
At any rate good luck on that. Mine is gonna get a custom swingarm, braided brake lines custom caliper and disc along with a 1075 and some nice cams to compliment it. Look forward to riding with you next summer. I have some rides in the plans that are scenic. Heck that ride we went on to St. Louis was killer. Shoulda been there.
79 LTD B3
- oldkaws4ever
- Have no regrets...... You only live once.
- Thank you received: 12
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- PLUMMEN
- Thank you received: 104
maybe its just my simple upbringing or maybe ive just breathed too many silicone fumes while smearing it on the head side of carb boots before installing them but nowhere in his postings do i see the words mk II brought up but i do see 74 z1 900 in his signature as you are always bring up for people to do.call me crazy but im thinking the camshafts that were recently removed from his motor would have the right sprockets to match his crankshaft sprocket.Note that no one mentioned that if the bottom end on this thing is a MK II type, the crank sprocket won't much like the cam sprockets on Z1 cams. Also, any rebuild should include ALL NEW cam chain and associated parts.
- mark1122
- Keep twisting it
- Thank you received: 109
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- oldkaws4ever
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- Old Man Rock
- Thank you received: 225
I did the same for in not knowing the history of my bike and since I had to split the cases for crank/gear/tranny inspections, replace the endless (link less) timing chain while in there...
Hell for a couple extra $$$, I replaced every damn thing in the the timing components...
Figured what the hell, piece of mind for the last thing I wanted is you go through all this work in the motor and because of being cheap something goes seriously wrong due to old worn out timing parts and all is lost....
Oh yeah, order yourself the 8 piece seal kit from Z1, all new gaskets as well....
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- oldkaws4ever
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- mark1122
- Keep twisting it
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- roy-b-boy-b
- Thank you received: 103
- saxjonz
- KawboyZ
May kaws be around for ever.
79 LTD B3
- oldkaws4ever
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- saxjonz
- KawboyZ
Did I mention, I think I did, that I am getting a 1075 and cams put in along with a custom swingarm to stretch about 2-3 inches from stock. I am excited about that. As for the other 79 I will get the engine balanced blueprinted, use the ceramic coated bearings have the gears back cut case powdercoated and maybe even the head and block. I tell you about 7gs later on just engine I think she should be quite righteous and then with the rest of the bike? I haven't decided on a paint and frame scheme yet but for sure some really nice wheels and stretched and a really nice seat. Ah well that is the long project for most of my money will go to pay off the house! lol If I kill myself doing that within a year and a half I should be able to get er paid off. Then the money will flow like a river into the sea with that bike. That is a nice big wet dream right now I dream from time to time.
79 LTD B3
