Just got my kz 1000 head and have ?'s already
  • oldkaws4ever
  • Topic Author
  • Have no regrets...... You only live once.
06 Jan 2009 18:38 #256485 by oldkaws4ever
Just got my kz 1000 head and have ?'s already was created by oldkaws4ever
Ok guys, i will be the first to admit this will be my first kawasaki motor that i tear apart and rebuild. The rebuild will consist of, a 1979 Kz 1000 head, hand lapped valves, stock pistons with new rings, new studs snd cap bolt's and thats pretty much it as far as new parts. Im also going to purchase the complete engine gasket kit from z1 enterprises. I have a question, would it be ok to run my z1 cams in the 1000 head?
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
06 Jan 2009 21:06 #256508 by PLUMMEN
Replied by PLUMMEN on topic Just got my kz 1000 head and have ?'s already
run whichever ones look better.i wouldnt worrie about new studs B)
  • oldkaws4ever
  • Topic Author
06 Jan 2009 21:28 #256513 by oldkaws4ever
Replied by oldkaws4ever on topic Just got my kz 1000 head and have ?'s already
that would be the z1 cams for sure, they are the same cams if im not mistaken right? I was talking about the cylinder studs, my motor has around 38,000 on her. Oh i scored a kz 1000 valve cover off ebay, and i bought a set of the APE block off plates, do i still have to block the 2 holes on the head under the plates?
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
06 Jan 2009 21:40 #256515 by PLUMMEN
stock cylinder studs and nuts should be fine,block off plates should cover everything.im not a big fan of lapping valves,not really affective imo anyway.with the valves and springs in motor flip it on the exhust side with intake ports pointing up take and fill intake ports full of solvent then take an air nozzle and blow air around edge of each intake valve where it meets the seat and look for air bubbles in ports through the solvent.then flip it over and do exhuast side,no bubbles ?valves are sealing.cheap and affective for a budget rebuild.B)
  • oldkaws4ever
  • Topic Author
06 Jan 2009 21:50 #256519 by oldkaws4ever
Thank ya plummen, cheap and affective two words i like to hear..........and ya its a budget rebuild how did ya know??????lol
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
07 Jan 2009 00:03 - 07 Jan 2009 00:04 #256522 by APE Jay
Replied by APE Jay on topic Just got my kz 1000 head and have ?'s already
Very good chance if the head is original that the guides would be shot.
Jay
Last edit: 07 Jan 2009 00:04 by APE Jay.
07 Jan 2009 08:33 #256552 by PLUMMEN
exactly Jay thats why i dont reccomend wasting time lapping the valves if your gonna take em out ya might as well do a real valve job and check guides and replace seals,i dont think its in his current budget though.;)
07 Jan 2009 10:53 #256568 by wiredgeorge
Replied by wiredgeorge on topic Just got my kz 1000 head and have ?'s already
Note that no one mentioned that if the bottom end on this thing is a MK II type, the crank sprocket won't much like the cam sprockets on Z1 cams. Also, any rebuild should include ALL NEW cam chain and associated parts.
  • oldkaws4ever
  • Topic Author
07 Jan 2009 13:13 #256574 by oldkaws4ever
Nope the motor is a 74 z1 900 not an MK II type;) ;) . Im not adding any more power, so i didnt think a new chain was needed, and it was a really quiet motor, so i think the cam chain parts are ok, but when i tear into it i will know for sure, if it needs replacing, i will replace it. Thanks
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
  • oldkaws4ever
  • Topic Author
07 Jan 2009 13:15 #256575 by oldkaws4ever
Jay
The head came off of a 7000 mile bike, would the guides be shot already? Maby next winter i will send the head to ya guys for a full rebuild. Thanks
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
07 Jan 2009 13:17 #256576 by bountyhunter
Replied by bountyhunter on topic Just got my kz 1000 head and have ?'s already
I would at least put in new valve seals... considering how mine keep going south.
  • oldkaws4ever
  • Topic Author
07 Jan 2009 13:22 #256579 by oldkaws4ever
I will keep that im mind for sure.....thanks
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
