more power?
- School Teacher
1976 kz900 in parts but will be going some day soon
1980 kz1000G1
1976 kz900 parts bike
1979 kz1000 shaftie parts bike
1978 kz1000 33mm smoothies 1075 kit
Troutdale Oregon USA
- nads.com
- Thank you received: 20
- Kawickrice
- Thank you received: 18
RUN for cover. I've been off this bike for a year and a half waiting for my driving privilages
Don't you think its fast enough?:woohoo: :woohoo: :woohoo: :woohoo:
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
- APE Jay
- Banned
- Thank you received: 58
You going to have the o'rings bite into the head?
Jay
- 77_650B1
1977 KZ650-B1
-Dual Discs
-Dyna-S
-WG Coil Mod
-Alloy Wheels
- nads.com
- 77KZ650
- Thank you received: 7
weld the head on... now thats a new one lol
07 MDP Rookie of the Year
- nads.com
- Old Man Rock
- Thank you received: 225
I'm presently in the CAM degreeing process and in my studying of the Dale Walker Cam Degreeing DVD and numerous articles on the subject matter, I find this is an exact setup requirement and precise procedure for dialing my motor in for optimum performance. Piston to head decking, piston chamber clearance, valve clearance, valve timing, shims, compression, advancing/retarding, cam lobe centering etc... all play an extremely important part for obtaining that goal!
In reading your replies, items such as "A little grinding here, a little banging there", "valve clearance is no concern since I measure it anyway whenever I make a change in cam timing or head gasket thickness.", "I have special o rings with teeth on them", "no gaskets" thus loss of compression not to mention oil all over the place, "RTV", "Now I want to try welding the bikes head", "If I lose too much valve clearance I'll cut the piston tops :blink: " etc.... on and on...
I think to myself...
1) Either you're truly good at this... Magician/Guru/Yoda Master...
2) You have no friggin idea what you're rambling on about.
3) You're full of it and just blowing smoke up our asses.
4) You're just really, really stoned! :blink:
Seriously, it's probably just me not understanding what you're posting in power quest but I'm having some real difficulty following this....:huh: :dry:
Ok, I'll be quiet now...
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- tw..
2-1976 KZ900 A4
1995 KZ1000 Police bike
1978 Z1R
- Thank you received: 2098
I forgot to RUN for cover, but at least I'm a quiet grabber. And I'll take Cam Degreeing for $200, Alex.
:laugh:
- mark1122
- Keep twisting it
- Thank you received: 109
Way more power can be had cheaper with higher compression pistions or bigger pistons and cams? Put the head on a flow bench.
If u reduce the squish too much u cant run pump gas, is that a consern?
i too am triing to find the magic # for squish clearance while on pump gas.
Its always fun to have an open dialog and hear all the opinions.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
